14 Replies Latest reply on Jan 7, 2013 9:53 AM by Harm Millaard
    Windows Experience Index 5.9 - Do I Need A New Hard Drive?
    alexdejesus Level 1
      System C Drive is an SSD, A is a RAID 0 (2 x 2 TB SATA III) and B is a RAID 0 (2 x 1.5 TB SATA II)
      The WEI was 7.2, but is now 5.9, because of 'Data Transfer Rate'  I get no other fail indications.
      I performed the PPMB6, although the 'statistics' function is not working. It rendered pretty slow with or without CUDA, but had nothing to compare to.
      Some info from Speccy:
      Win 7 Ultimate 64-bit
      32 GB RAM
      Hard Drives
      A Drive: Projects
            Interface RAID
         Capacity 3726GB
         Real size 4,000,792,444,928 bytes
         RAID Type Software RAID
          S.M.A.R.T
          Partition 0
           Partition ID Disk #0, Partition #0
           Disk Letter A:
           File System NTFS
           Volume Serial Number E6DF8ADC
           Size 3726GB
           Used Space 1650GB (45%)
           Free Space 2076GB (55%)
      B Drive: PreviewPagefile
            Serial Number ?? ?????k? ?????
         Interface SATA
         Capacity 2795GB
         Real size 3,000,598,790,144 bytes
         RAID Type None
          S.M.A.R.T
          Partition 0
           Partition ID Disk #1, Partition #0
           Disk Letter B:
           File System NTFS
           Volume Serial Number 7427F143
           Size 2794GB
           Used Space 690GB (25%)
           Free Space 2105GB (75%)
      C Drive: Patriot Wildfire SSD
            Serial Number PT1145A00024401
         LBA Size 48-bit LBA
         Power On Count 283 times
         Power On Time 321.7 days
         Speed, Expressed in Revolutions Per Minute (rpm) Not used (SSD Drive)
         Features S.M.A.R.T., APM, NCQ, TRIM, SSD
         Transfer Mode SATA III
         Interface SATA
         Capacity 112GB
         Real size 120,034,123,776 bytes
         RAID Type None
          S.M.A.R.T
           01 Read Error Rate 089 (089 worst) Data 000323C9F1
           05 Reallocated Sectors Count 100 (100) Data 0000000000
           09 Power-On Hours (POH) 092 (092) Data 0000001E29
           0C Device Power Cycle Count 100 (100) Data 000000011B
           AB 000 (000) Data 0000000000
           AC 000 (000) Data 0000000000
           AE 000 (000) Data 000000005A
           B1 000 (000) Data 0000000004
           B5 000 (000) Data 0000000000
           B6 000 (000) Data 0000000000
           BB Reported Uncorrectable Errors 100 (100) Data 0000000000
           C2 Temperature 028 (057) Data 000039001C
           C3 Hardware ECC Recovered 120 (120) Data 000323C9F1
           C4 Reallocation Event Count 100 (100) Data 0000000000
           C9 Soft Read Error Rate 120 (120) Data 000323C9F1
           CC Soft ECC Correction 120 (120) Data 000323C9F1
           E6 GMR Head Amplitude 100 (100) Data 0000000064
           E7 Temperature 100 (100) Data 0000000000
           E9 000 (000) Data 00000011DB
           EA 000 (000) Data 0000000FD7
           F1 Total LBAs Written 000 (000) Data 0000000FD7
           F2 Total LBAs Read 000 (000) Data 00000021BE
           Temperature 28 °C
           Temperature Range ok (less than 50 °C)
           Status Good
          Partition 0
           Partition ID Disk #2, Partition #0
           Disk Letter C:
           File System NTFS
           Volume Serial Number A27724F8
           Size 112GB
           Used Space 68GB (61%)
           Free Space 44GB (39%)
      Motherboard
      Manufacturer ASUSTeK Computer INC.
      Model P8P67 PRO (LGA1155)
      Version System Version
      Chipset Vendor Intel
      Chipset Model Sandy Bridge
      Chipset Revision 09
      Southbridge Vendor Intel
      Southbridge Model P67
      Southbridge Revision B3
      System Temperature 32 °C
        BIOS
         Brand American Megatrends Inc.
         Version 3602
         Date 11/01/2012
        Voltage
         CPU CORE 1.040 V
         MEMORY CONTROLLER 1.024 V
         AVCC 3.392 V
         3VCC 3.376 V
         VIN4 1.008 V
         VIN6 0.832 V
      CPU
        Intel Core i7 2600K
      Graphics
      NVIDIA GeForce GTX 580
