3 Replies Latest reply on Jan 8, 2013 6:23 PM by kglad
    Hairpulling Debug session
      Hi folks,
      I'm not a a maven, just a neophyte when it comes to FL CS5 AS2.
      I did succesfully create a "photo viewer" a couple of years ago.
      I'm tweaking it now,  reacquainting myself with the interface and in absolute consternation by whats happening.  I'm convinced its a setting or two thats causing the bizarreness.
      If you could please assist me with a Debug and a compile issue:
      1 Debug Issue)  When I Debug->Debug Movie->Debug  the swf loads ok. it generally works ok.  but there are some "variables" that I'd like to scope -- but can't because the debug console & variables panel remain empty/blank the entire time.
      For example, from my F9-Actions (see snippet below),   I'd like to see what txtPos.text is before and  and after the assignment. Setting a break point immediately before works -- but _nothing_ displays in the debug panels.  I can't see anything -- not a call stack, not objects, not vars,  nothing.
      2 Compile Issue)  If I change the var name txtPos to txtBlahBlahBlah and attempt publish or debug  I get no compiler, output or runtime errors.  Shouldn't I?  Can't I?   In this specific I want to change the text on "screen" -- and I don't seem to see the "object" that the actionscript references
      so I'm expecting a "variable not found" kind of error -- but nothing -- the script just chugs right on through.
      Stranger,  when I create a text object in my "textfield" layer, name it txtPos (classic/dynamic) None of the above symptoms changes and the onscreen contents of my (new) txtPos is unchanged.
      function picture_num() {
      current_pos = p+1;
      txtPos.text = current_pos+" / "+total;
      I'm sure I was able to debug successfully back when so I'm obviously missing something now
      thanks for any help offered.
        • 1. Re: Hairpulling Debug session
          I haveb't much experience with the debugger, so it's better that I don't try to answer for it.
          I seldom found AS2 to be very helpful when it comes to letting you know when there's a coding problem.   Very often it just plays thru a failure without any indication.  If you make the switch to AS3 you will find every error you make gets presented.
          • 2. Re: Hairpulling Debug session
            rokosz Level 1
            Ok, I understand what you're saying re: the possibility of AS2 failing without notification -- but what of the Debug panels: "Console" and "Variables" remaining empty voids while debugging?
            The latest and greatest is always presumed to be better (ie AS3), but certainly a glaring situation like empty debug panels is not something that the community or, I presume, Adobe, would let pass without action -- so again: Are there particular settings necessary to activate the debug console and variable panels?
            • 3. Re: Hairpulling Debug session
              there's nothing in the debug panels that is needed for debugging.  the flash trace() is more flexible and more informative than those panels.
