4 Replies Latest reply on Jan 7, 2013 4:46 PM by Sham HC
    Errors when (re)activating digital assets on a new Publish install
    cgill-pwe
      Greetings,
      First post here, and I'm also not very well versed with Adobe CQ (yet), so bear with me:
      I've configured an Author instance in a dev environemtnt, got it up and running, updated, etc and created workflows, set up replication, done all the basics.
      After a failed attempt to upgrade our Publish instance to CQ5 SP2.2, I recreated it from scratch. I set up replication again with our Author instance, and started reactivating Workflows/Users/Websites/etc.
      I started to reactivate our Digital Assets (we have many gigs of pictures/movies) and this is where I ran into some problems.
      I was performing a tree activation on a folder under the Digital Assets, when I noticed that we had something like 300 items stuck in the replication queue.
      I dug into the replication event log and was greeted with the following error:
      7.01.2013 12:52:01 - DEBUG - publish : adding header: Action:Activate
      07.01.2013 12:52:01 - DEBUG - publish : adding header: Path:/content/dam/WIP/NW/screenshots/Vellosk_Lore_Trailer_Screenshots/neverwinter_e3_scre en7.jpg
      07.01.2013 12:52:01 - DEBUG - publish : adding header: Handle:/content/dam/WIP/NW/screenshots/Vellosk_Lore_Trailer_Screenshots/neverwinter_e3_sc reen7.jpg
      07.01.2013 12:52:01 - DEBUG - publish : deserialize content for delivery
      07.01.2013 12:52:01 - DEBUG - publish : set 1306653 bytes of post body.
      07.01.2013 12:52:01 - INFO - publish : Sending POST request to http://eve/bin/receive?sling:authRequestLogin=1
      07.01.2013 12:52:01 - INFO - publish : sent. Response: 400 Bad Request
      07.01.2013 12:52:01 - ERROR - publish : Replication (ACTIVATE) of /content/dam/WIP/NW/screenshots/Vellosk_Lore_Trailer_Screenshots/neverwinter_e3_screen7.j pg not successful. Conversation follows
      07.01.2013 12:52:01 - ERROR - publish : ------------------------------------------------
      07.01.2013 12:52:01 - ERROR - publish : Sending message to eve:-1
      07.01.2013 12:52:01 - ERROR - publish : >> POST /bin/receive HTTP/1.0
      07.01.2013 12:52:01 - ERROR - publish : >> Action: Activate
      07.01.2013 12:52:01 - ERROR - publish : >> Path: /content/dam/WIP/NW/screenshots/Vellosk_Lore_Trailer_Screenshots/neverwinter_e3_screen7.j pg
      07.01.2013 12:52:01 - ERROR - publish : >> Handle: /content/dam/WIP/NW/screenshots/Vellosk_Lore_Trailer_Screenshots/neverwinter_e3_screen7.j pg
      07.01.2013 12:52:01 - ERROR - publish : >> ...spooling 1306653 bytes...
      07.01.2013 12:52:01 - ERROR - publish : << HTTP/1.1 400 Bad Request
      07.01.2013 12:52:01 - ERROR - publish : << Connection: Close
      07.01.2013 12:52:01 - ERROR - publish : << Server: Day-Servlet-Engine/4.1.32
      07.01.2013 12:52:01 - ERROR - publish : << Content-Type: text/plain;charset=utf-8
      07.01.2013 12:52:01 - ERROR - publish : << Content-Length: 130
      07.01.2013 12:52:01 - ERROR - publish : << Date: Mon, 07 Jan 2013 20:52:01 GMT
      07.01.2013 12:52:01 - ERROR - publish : << error: com.day.cq.replication.ReplicationException: Repository error during page import: The system cannot find the path specified
      07.01.2013 12:52:01 - ERROR - publish : Message sent.
      07.01.2013 12:52:01 - INFO - publish : Replication (ACTIVATE) of /content/dam/WIP/NW/screenshots/Vellosk_Lore_Trailer_Screenshots/neverwinter_e3_screen7.j pg not successful.
      I can't for the life of me find anything on Google that might have more information on this issue (or the cause). Could anyone point me in the right direction to resolve this issue?
      Thanks!
        • 1. Re: Errors when (re)activating digital assets on a new Publish install
          Sham HC Level 7
          For large assets I would recommend to create a package and activate it.  For now please follow https://helpx.adobe.com/cq/kb/replication-stuck.html
          • 2. Re: Errors when (re)activating digital assets on a new Publish install
            orotas Level 4
            Have you looked at error.log on your publish instance. Sometimes when you get a error like that it is indicative of some problem in your publish server repository and the publish server's error logs will provide more information than the replication logs on the author machine.
            • 3. Re: Errors when (re)activating digital assets on a new Publish install
              cgill-pwe Level 1
              Thanks for the response, I've checked the Publish error logs and found the following large Java stack trace. For someone who is completely unfamiliar with Java, what would be a good starting point to troubleshoot this problem?
              I've already opened a ticket with Adobe support, but seeing as their response time ranges from 8 - 24 hours, I'd like to poke around and see what I can fine first...
              07.01.2013 16:13:49.324 *ERROR* [172.28.8.22 [1357604029309] POST /bin/receive HTTP/1.1] com.day.cq.replication.impl.servlets.ReplicationServlet Error during replication: Repository error during page import: The system cannot find the path specified com.day.cq.replication.ReplicationException: Repository error during page import: The system cannot find the path specified
                        at com.day.cq.replication.impl.content.durbo.DurboImporter.createPage(DurboImporter.java:192 )
                        at com.day.cq.replication.impl.ReplicationReceiverImpl.receive(ReplicationReceiverImpl.java: 106)
                        at com.day.cq.replication.impl.servlets.ReplicationServlet.doPost(ReplicationServlet.java:11 2)
                        at org.apache.sling.api.servlets.SlingAllMethodsServlet.mayService(SlingAllMethodsServlet.ja va:148)
                        at org.apache.sling.api.servlets.SlingSafeMethodsServlet.service(SlingSafeMethodsServlet.jav a:344)
                        at org.apache.sling.api.servlets.SlingSafeMethodsServlet.service(SlingSafeMethodsServlet.jav a:375)
                        at org.apache.sling.engine.impl.request.RequestData.service(RequestData.java:500)
                        at org.apache.sling.engine.impl.filter.SlingComponentFilterChain.render(SlingComponentFilter Chain.java:45)
                        at org.apache.sling.engine.impl.filter.AbstractSlingFilterChain.doFilter(AbstractSlingFilter Chain.java:64)
                        at com.day.cq.wcm.core.impl.WCMDebugFilter.doFilter(WCMDebugFilter.java:147)
                        at org.apache.sling.engine.impl.filter.AbstractSlingFilterChain.doFilter(AbstractSlingFilter Chain.java:60)
                        at com.day.cq.wcm.core.impl.WCMComponentFilter.filterRootInclude(WCMComponentFilter.java:308 )
                        at com.day.cq.wcm.core.impl.WCMComponentFilter.doFilter(WCMComponentFilter.java:141)
                        at org.apache.sling.engine.impl.SlingRequestProcessorImpl.processComponent(SlingRequestProce ssorImpl.java:257)
                        at org.apache.sling.engine.impl.filter.RequestSlingFilterChain.render(RequestSlingFilterChai n.java:49)
                        at com.day.cq.wcm.core.impl.warp.TimeWarpFilter.doFilter(TimeWarpFilter.java:106)
                        at com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter.doFilter(RedirectFilter.java:305)
                        at org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter.doFilter(RequestProgre ssTrackerLogFilter.java:59)
                        at com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet.doFilter(FormsHandlingServlet.j ava:220)
                        at com.day.cq.theme.impl.ThemeResolverFilter.doFilter(ThemeResolverFilter.java:76)
                        at com.day.cq.wcm.core.impl.WCMRequestFilter.doFilter(WCMRequestFilter.java:89)
                        at org.apache.sling.rewriter.impl.RewriterFilter.doFilter(RewriterFilter.java:83)
                        at org.apache.sling.i18n.impl.I18NFilter.doFilter(I18NFilter.java:117)
                        at org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter.doFilter(BackgroundServle tStarterFilter.java:135)
                        at org.apache.sling.engine.impl.SlingRequestProcessorImpl.processRequest(SlingRequestProcess orImpl.java:153)
                        at org.apache.sling.engine.impl.SlingMainServlet.service(SlingMainServlet.java:206)
                        at org.apache.felix.http.base.internal.handler.ServletHandler.doHandle(ServletHandler.java:9 6)
                        at org.apache.felix.http.base.internal.handler.ServletHandler.handle(ServletHandler.java:79)
                        at org.apache.felix.http.base.internal.dispatch.ServletPipeline.handle(ServletPipeline.java: 42)
                        at org.apache.felix.http.base.internal.dispatch.InvocationFilterChain.doFilter(InvocationFil terChain.java:49)
                        at org.apache.felix.http.base.internal.dispatch.HttpFilterChain.doFilter(HttpFilterChain.jav a:33)
                        at org.apache.felix.http.base.internal.handler.FilterHandler.doHandle(FilterHandler.java:88)
                        at org.apache.felix.http.base.internal.handler.FilterHandler.handle(FilterHandler.java:76)
                        at org.apache.felix.http.base.internal.dispatch.InvocationFilterChain.doFilter(InvocationFil terChain.java:47)
                        at org.apache.sling.security.impl.ReferrerFilter.doFilter(ReferrerFilter.java:238)
                        at com.adobe.granite.license.impl.LicenseCheckFilter.doFilter(LicenseCheckFilter.java:179)
                        at org.apache.sling.engine.impl.log.RequestLoggerFilter.doFilter(RequestLoggerFilter.java:75 )
                        at org.apache.felix.http.base.internal.dispatch.FilterPipeline.dispatch(FilterPipeline.java: 48)
                        at org.apache.felix.http.base.internal.dispatch.Dispatcher.dispatch(Dispatcher.java:39)
                        at org.apache.felix.http.base.internal.DispatcherServlet.service(DispatcherServlet.java:67)
                        at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
                        at com.day.j2ee.servletengine.ServletRuntimeEnvironment.service(ServletRuntimeEnvironment.ja va:250)
                        at com.day.j2ee.servletengine.RequestDispatcherImpl.doFilter(RequestDispatcherImpl.java:321)
                        at com.day.j2ee.servletengine.RequestDispatcherImpl.service(RequestDispatcherImpl.java:340)
                        at com.day.j2ee.servletengine.RequestDispatcherImpl.service(RequestDispatcherImpl.java:383)
                        at com.day.j2ee.servletengine.ServletHandlerImpl.process(ServletHandlerImpl.java:351)
                        at com.day.j2ee.servletengine.HttpListener$Worker.run(HttpListener.java:625)
                        at java.lang.Thread.run(Unknown Source)
              • 4. Re: Errors when (re)activating digital assets on a new Publish install
                Sham HC Level 7
                In your agent configuration missing the required query parameter. It should be like [1]. Though it should not cause the issue.  As you have filed daycare the team will look into more & update you.     In the agent are you using the user id as admin Or using Different replication  user?   Do you see any errors in publish instance indicating repository is inconsistent. Errors like [2]
                [1]   http://<host>:<port>/bin/receive?sling:authRequestLogin=1
                [2]     https://helpx.adobe.com/crx/kb/RepositoryInconsistency.html
