3 Replies Latest reply on Apr 1, 2009 10:17 AM by kgorham
    Unable to start Flex Builder
    oakmad
      Is anyone else having trouble with starting Flex Builder 2 (stand alone, not the plugin) with OS X 10.5? It worked fine with 10.4 and now after upgrading it throws an error everytime I try to start it. The error just states " An Error has Occurred" and to check my log file (below). I tried also downloading a copy of eclipse 3.2 and got the same error, so its eclipse/java related I think. An install of Eclipse 3.3 I have is working without any troubles at all. Any ideas?
      Thanks - I have code to work on and am getting desperate
      Adam
      The log has been truncated due to message length constraints - I removed much of the stack trace to just keep the errors
      !SESSION 2007-11-26 16:31:26.266 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.5.0_13
      java.vendor=Apple Inc.
      BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
      Command-line arguments: -os macosx -ws carbon
      !ENTRY org.eclipse.update.configurator 4 0 2007-11-26 16:31:26.636
      !MESSAGE FrameworkEvent.ERROR
      !STACK 0
      org.osgi.framework.BundleException: Exception in org.eclipse.update.internal.configurator.ConfigurationActivator.start() of bundle org.eclipse.update.configurator.
      Root exception:
      org.eclipse.core.runtime.CoreException: Cannot create configuration in file:/Applications/Adobe Flex Builder 2/configuration/
      !ENTRY org.eclipse.osgi 4 0 2007-11-26 16:31:26.785
      !MESSAGE Bundle initial@reference:file:plugins/org.eclipse.update.configurator_3.2.1.v20092006.jar/ [2] is not active.
      !ENTRY org.eclipse.osgi 4 0 2007-11-26 16:31:26.796
      !MESSAGE An error occurred while automatically activating bundle org.eclipse.update.configurator (2).
      !STACK 0
      Root exception:
      !ENTRY org.eclipse.osgi 4 0 2007-11-26 16:31:26.798
      !MESSAGE An error occurred while automatically activating bundle org.eclipse.update.core (77).
      !STACK 0
      org.osgi.framework.BundleException: Exception in org.eclipse.update.internal.core.UpdateCore.start() of bundle org.eclipse.update.core.
      Root exception:
      java.lang.NoClassDefFoundError: org/eclipse/update/configurator/ConfiguratorUtils
      !ENTRY org.eclipse.osgi 4 0 2007-11-26 16:31:26.800
      !MESSAGE Application error
      !STACK 1
      java.lang.ClassCastException: [Ljava.lang.Object;
        • 1. Re: Unable to start Flex Builder
          kgorham
          I'm having the same problem. I've installed Flex Builder 3.0 (stand alone) on my Mac and, immediately, when I run the application. I get the error below.
          I've tried uninstalling and reinstalling Flex Builder 3.0 with no luck. It runs fine on computers in my office that are similarly configured. I'm guessing that it has something to do with a version issue or permissions issue (while installing) or something.
          !SESSION 2009-03-31 16:21:01.810 -----------------------------------------------
          java.version=1.5.0_16
          Command-line arguments: -os macosx -ws carbon -arch x86 -clean
          !ENTRY org.eclipse.osgi 4 0 2009-03-31 16:21:03.936
          !MESSAGE An error occurred while automatically activating bundle com.adobe.flexbuilder.project (34).
          !STACK 0
          org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:1018)
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:9 74)
          at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
          at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:260)
          at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
          at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:111)
          at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :417)
          at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:189)
          at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:34 0)
          at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackag e.java:37)
          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java :405)
          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:369)
          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:357)
          at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:83)
          at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
          at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:374)
          at java.lang.Class.getDeclaredConstructors0(Native Method)
          at java.lang.Class.privateGetDeclaredConstructors(Class.java:2357)
          at java.lang.Class.getConstructor0(Class.java:2671)
          at java.lang.Class.newInstance0(Class.java:321)
          at java.lang.Class.newInstance(Class.java:303)
          at com.adobe.flexbuilder.standalone.FlexBuilderApplication$1.run(FlexBuilderApplication.java :101)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:123)
          at org.eclipse.swt.widgets.Display.setSynchronizer(Display.java:3685)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2239)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2219)
          at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:289)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:461)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java :112)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:169)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:106)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:76)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:363)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:176)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:585)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:508)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
          Caused by: java.io.FileNotFoundException: /Users/kevinvgorham/Library/Preferences/Macromedia/Flash Player/#Security/FlashPlayerTrust/flexbuilder.fbr (No such file or directory)
          at java.io.FileOutputStream.open(Native Method)
          at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
          at java.io.FileOutputStream.<init>(FileOutputStream.java:70)
          at java.io.FileWriter.<init>(FileWriter.java:46)
          at com.adobe.flexbuilder.project.internal.PlayerTrustStore.write(Unknown Source)
          at com.adobe.flexbuilder.project.internal.PlayerTrustStore.<init>(Unknown Source)
          at com.adobe.flexbuilder.project.internal.PlayerTrustStore.getInstance(Unknown Source)
          at com.adobe.flexbuilder.project.internal.FlexProjectCore.start(Unknown Source)
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:9 99)
          at java.security.AccessController.doPrivileged(Native Method)
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:993)
          ... 43 more
          Root exception:
          • 2. Unable to start Flex Builder
            kgorham Level 1
            [accidental duplicate]
