1 Reply Latest reply on Jan 13, 2013 1:46 AM by BKBK
    Passing variables to command line script
      I have the following script that is meant to create a mysql database on a remote server using values passed into it:-
      set arg1=\\\e$\Program Files\MySQL\MySQL Server 5.5\bin  set arg2=  set arg3=%1    echo %arg1%  echo %arg2%  echo %arg3%    pushd %arg1%  mysql -uignite -h %arg2% -p***** -e "CREATE DATABASE %arg3%"    pause
      If I place a value in arg3 - i.e. MYDatabaseName, then the script runs and fine from a web page that use the following coldfusion code to call the script:-
      <cfexecute name="fullpathtocmdfile\AddDatabase.cmd"  arguments="'MyDatabaseName'">  </cfexecute>
      But if I keep the %1 in there - ie the holder for the variable - then it doesn't seem to pick it up and create the database.
      Am I using the correct syntax to pass the variable into the file?
      Any help greatly appreciated
