1. Re: Do you deploy courseware to a LMS? (exit the course - revisited)
ureymills00 Jan 9, 2013 8:27 AM (in response to shawninvancouver)Currently, I am publishing the course to successfactors LMS. The exit button does not appear to work at least not the first time. Currently, I am using out of the box Captivate 6.0 functionality.
Currently, I am trying to get the Resume message to appear when I go back to the course. Currently, the course simply restarts where I left off with no option to start over.
2. Re: Do you deploy courseware to a LMS? (exit the course - revisited)
www.cpguru.com Jan 9, 2013 12:36 PM (in response to ureymills00)
Currently, I am trying to get the Resume message to appear when I go back to the course. Currently, the course simply restarts where I left off with no option to start over.You won't get a "Resume message" when you are deploying to an LMS. The default (and non-changeable) behavior of Bookmark/Resume functionality in Adobe Captivate is to simply teleport the user to the last visited slide without any option to say yes or no.
The only time you get a "Resume message" is if you use Self-Paced Learning from the TOC, but in this case the Bookmark is saved locally on the users machine and you would also have to disable the SCORM bookmark (by selecting "Never send resume data" in the Quiz Settings) as this is enabled by default.
(sorry Shawn for hijacking your post)
3. Re: Do you deploy courseware to a LMS? (exit the course - revisited)
ureymills00 Jan 16, 2013 8:23 AM (in response to www.cpguru.com)Thank you, will a widget work if using Flash?
And, yes, sorry Shawn.
4. Re: Do you deploy courseware to a LMS? (exit the course - revisited)
shawninvancouver Jan 16, 2013 11:03 AM (in response to www.cpguru.com)Hello Michael,
If not deploying to a LMS, the Captivate will automatically offer a resume message. You are correct about the resume message not appearing when a Captivate project is deployed to a LMS. While some LMS will actually handle the resume message, many will not. Adobe needs to make this better. I encourage others to pester Adobe development to correct this problem.
No problem on hijacking the post.
But I think you have this wrong (unless I misunderstood). If publishing to a LMS that doesn't support its own resume message, the learner will always continue from the position they left.
In my situation, if I cannot give the learner a choice, I want to force the learner to restart from the beginning of the lesson. The solution is to select "Never Send Resume Data". The default is actually unselected.
Shawn
5. Re: Do you deploy courseware to a LMS? (exit the course - revisited)
www.cpguru.com Jan 16, 2013 11:32 AM (in response to shawninvancouver)Hi Shawn,
Captivate offers two separate bookmark / resume mechanisms.
1) The Self-paced learning / TOC option, which brings you the standard (not very appealing and not custimizable) Adobe Captivate resume message. The bookmark is stored a as "Flash cookie" on the users machine. If you use this in an LMS (and have enabled "Never Send Resume Data") then you would be able to get a prompt, but it is not a true bookmark as it is not stored in the LMS database, but instead on the computer used to access the course.
2) The "SCORM" bookmark / resume functionality, which is enabled by default when you publish your course to an LMS and which doesn't offer a resume message, but simply teleports the user to the last location.
When using the SCORM bookmark there is no way to get a resume message to the user. Typically a SCORM bookmark / resume point isn't actually handled by the LMS (it's only stored in the LMS database) but it is handled by the SCORM content. This applies for Captivate as well. The Bookmark / Resume functionality that Captivate uses is built into the Captivate SWF and basically what it does it to read the value of the SCORM field "cmi.core.lesson_location" (SCORM 1.2) or "cmi.location" (SCORM 2004) and then teleport the user there. The LMS does not have any control over this and any prompt to the users should be initiated by Captivate, but unfortunately that is not supported.
As you write yourself you can actually disable the SCORM bookmark functionality by enabling "Never Send Resume Data" and this is what I consistently do on all Captivate courses published to an LMS. It's not very user friendly to just teleport a user to a certain page and in Captivate 4, 5 and 5.5 it is even worse because once the user reaches the last page of the course this page will be bookmarked for ever and ever, constantly teleporting the user to the last page in your course when it is relaunched. This problem is fixed in Captivate 6 though (if you enable the setting).
@ureymills00 - Yes you can do this with a widget, but it would be a custom programming job because the widget would need to be able to initiate and communicate with your LMS in order to set and retrieve values to and from the database. Not two LMS's are alike, so it will be difficult to create a generic widget that would work across the board, but a custom widget built to your specific LMS should work.
www.cpguru.com - Adobe Captivate Widgets, Tutorials, Tips and Tricks and much more.. -
6. Re: Do you deploy courseware to a LMS? (exit the course - revisited)
ureymills00 Jan 21, 2013 6:54 AM (in response to www.cpguru.com)Thank you so much for your very helpful and thorough feedback, much appreciated!
