6 Replies Latest reply on Jan 10, 2013 3:22 AM by Jump_Over
    dropdown list not sorted
    gert verrept Level 2
      We use a script to open specific templates. The script looks at a specific folder and displays a list of all files ending on "INDT". Displaying the folder in explorer, we get this
      ScreenShot1.jpgwhen we use the script, it becomes:
      Next is part of the script used:
      var ini_bestand = File((Folder(app.activeScript)).parent + "/mstr.txt"); //--------mstr.txt=where is folder located
      initialiseer_map();
      lees_mapnaam_uit();
      var masterpages = Folder(folder_masters).getFiles("*.indt");//---------all templates have 3 pages, when opening template, add 25 pages and link textframes
      var aantal_masters = masterpages.length;
      var aantal_paginas = 25;
      var master_pages_lijst = new Array;
      for (i=0; i<aantal_masters; i++) {
                master_pages_lijst.push(masterpages[i].name);
      //menu laten zien
      var stramien_pagina_menu = stramienpagina();
      //stramienpagina openen
      if (stramien_pagina_menu.show()){
                app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
                app.open(masterpages[stramien_lijst.selectedIndex]);
                app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                pagina_aantal = app.activeDocument.pages.length; //-------when we select a template 25 pages are added
                if (pagina_aantal > 1) {
                          if (masterpages[stramien_lijst.selectedIndex] != "/p/20_DOCUMENTS/MASTERS/MSTR_PRC.indt") {
                          if (masterpages[stramien_lijst.selectedIndex] != "/p/20_DOCUMENTS/MASTERS/MSTR_PRC_TRAITE.indt") {
                          if (masterpages[stramien_lijst.selectedIndex] != "/p/20_DOCUMENTS/MASTERS/MSTR_PRC_NATUUR.indt") {
                          voeg_paginas_toe();
                          link_tekstframes();
                app.activeWindow.activePage = app.activeDocument.pages.item(0);
      //functies------------------------------------------------------------
      function stramienpagina(){
      var stramien = app.dialogs.add({name:"Master document", canCancel:true} );
                with (stramien){
                          with (dialogColumns.add() ){
                                    //tekstregel plaatsen
                                    with (dialogRows.add() ){
                                                        staticTexts.add({staticLabel:"Select the master needed!                 "} );
                                                        staticTexts.add({staticLabel:""} );
                                    //dropdowns plaatsen
                                    stramien_lijst = dropdowns.add({stringList:master_pages_lijst,selectedIndex:0}); //-------this list isn't sorted
                return stramien;
      the rest of the script isn't of any use, it links the frames on the template etc.
      All suggestions are welcome. (We use cs6 on win 7 pro 64bit)
        • 1. Re: dropdown list not sorted
          -hans- Level 4
          simple JS-sort inserted anywhere should be enough
          master_pages_lijst.sort();
          • 2. Re: dropdown list not sorted
            Thnkx hans works fine
            • 3. Re: dropdown list not sorted
              Jump_Over Level 5
              Sorting a list should help but notice that only array with names is sorted (dialog dropdown list).
              So stramien_lijst.selectedIndex is not an index of your chosen masterFile anymore.
              Since getFiles() gives you an array of files ==> sort this  before you create an array with names.
              This way you share an index in both arrays.
              To sort an array of files by their names you could use a function:
              function sortNames(file1,file2) {
              return (file1.name>file2.name);
              and in your code:
              masterpages.sort(sortNames)     // here your array with files supposes to be sorted
              rgds
              • 4. Re: dropdown list not sorted
                -hans- Level 4
                Hi Gert,
                as you return the index Jump_Over is, of course, right!
                • 5. Re: dropdown list not sorted
                  For proper execution, I think this would need to be changed:
                  It's a common misconception that sort needs to return 'true' or 'false'. Actually, the sort function needs to be able to return *three* values: Smaller, Same, and Greater, indicated by a negative number, zero, and a positive number. (Although in fairness it's unlikely you'd find two files with a "same" filename -- nevertheless, you might if you read files from several folders.)
                  The proper function to use is localeCompare, and it returns the 'proper' comparison right away:
                  return file1.name.localeCompare(file2.name);
                  By way of bonus, it'll also sort accented characters correctly :-)
                  • 6. Re: dropdown list not sorted
                    Jump_Over Level 5
                    What I need to return is three times "YES".
                    Thanks Jongware:)
