1 Reply Latest reply on Jan 12, 2013 11:09 AM by BKBK
    SOAP cfhttpparam header syntax
    totalpackage612
      I need to make a secure SOAP request with Coldfusion , and I'm having trouble implementing the headers properly so the service can use it.
      There are two structure examples I was given
      Example 1:
      This is a sample soap request:
      POST /WebService/EmployerWebServiceV24.asmx HTTP/1.1
      Host: stage.e-verify.uscis.gov
      Content-Type: text/xml; charset=utf-8
      Content-Length: length
      SOAPAction: "https://www.vis-dhs.com/EmployerWebService/EmpCpsVerifyConnection"
      <soap:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/">
        <soap:Body>
          <EmpCpsVerifyConnection xmlns="https://www.vis-dhs.com/EmployerWebService/" />
        </soap:Body>
      </soap:Envelope>
      Example 2:
      An example SOAP authentication HEADER would look something like:
          <soap:Header>
              <wsse:Security soap:mustUnderstand="1">
                  <wsse:UsernameToken namespaces>
                      <wsse:Username>username</wsse:Username>
                      <wsse:Password Type="type info">password</wsse:Password>
                      <wsse:Nonce>nonce</wsse:Nonce>
                      <wsu:Created>date created</wsu:Created>
                  </wsse:UsernameToken>
              <wsse:Security>
          </soap:Header>
          <soap:Body>
              <WebServiceMethodName xmlns="Web Service Namespace" />
          </soap:Body>
      </soap:Envelope>
      Important:
      I was able to create a successful connection to this web service without including header information.
      To use other functions I need a properly working header which works.
      This is my code for the successful connection without the headers. (So you can reproduce it)
      <cfsavecontent variable="request_xml">
      <cfoutput>
        <soap:Body>
        </soap:Body>
      </soap:Envelope>
      </cfoutput>
      </cfsavecontent>
      <!--- Make Request --->
      <cfhttp url="https://stage.e-verify.uscis.gov/WebService/EmployerWebServiceV24.asmx?wsdl" method="post" result="httpResponse">
        <cfhttpparam type="header" name="SOAPAction" value="https://www.vis-dhs.com/EmployerWebService/EmpCpsVerifyConnection" />
        <cfhttpparam type="header" name="accept-encoding" value="no-compression" />
        <cfhttpparam type="body" value="#trim(request_xml)#" />
      </cfhttp>
      <!--- Show Response --->
      <cfdump var="#httpResponse#" label="httpResponse">
      <cfdump var="#xmlParse( httpResponse.fileContent )#" label="soapResponse">
      PROBLEM:
      When I insert my header into the request, then it throws me an error saying "code:InvalidSecurityToken"
      (Replace cfsavecontent with this)
      <!--- Define Nonce --->
      <cfscript>
        strNonce = ToBase64(createUUID());
      </cfscript>
      <cfoutput>
        <soap:Header>
          <wsse:Security soap:mustUnderstand="1" xmlns:wsse="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
              <wsse:UsernameToken wsu:Id="UsernameToken-1" xmlns:wsu="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">
                  <wsse:Username>myUsername</wsse:Username>
                  <wsse:Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0##PasswordText">myPassword</wsse:Password>
                  <wsse:Nonce>#strNonce#</wsse:Nonce>
                  <wsu:Created>#Dateformat(Now(),'yyyy-mm-ddThh:mm:ss')#Z</wsu:Created>
          </wsse:Security>
        </soap:Header>
        <soap:Body>
        </soap:Body>
      </soap:Envelope>
      </cfoutput>
      </cfsavecontent>
      OTHER SOLUTIONS I HAVE TRIED:
      I have tried to use createObject + AddSOAPRequestHeader + cfinvoke but nothing seems to work for me
      WHAT I NEED
      I need some ideas on how to get that secure header working using a cfhttp method.
      After 8 hours of researching I have found nothing.
