7 Replies Latest reply on Jan 9, 2013 2:36 PM by pixxxel schubser
    Basic question, duplicating a circle with javascript
    maguskrool Level 1
      Hello. I'm trying to build something like a bullseye using javascript. I'm new to scripting for Illustrator but I've used javascript before so I thought it would be simple, but maybe I'm missing some basic notions here.
      I'm using Illustrator CS6. I created a blank document and drew a circle with a 1pt black stroke and no fill. Selecting that circle, I my script to copy and paste it in front and increase its radius by one centimeter. I attempted a simple duplication first:
      if ( app.documents.length > 0 ) {
          var numberOfItems = 3;
          var selectedItem = app.activeDocument.selection;
          for (i=0; i < numberOfItems; i++) {
               newItem = selectedItem.duplicate();
      With my circle selected I get an error message saying "Error 24: selectedItem.duplicate() is not a function". What am I doing wrong?
      Thank you in advance.
        • 1. Re: Basic question, duplicating a circle with javascript
          maguskrool Level 1
          Ok, solved this one when I realized that app.activeDocument.selection returned an array of objects. So now I've got:
              var newItem;
              var radiusIncrease = 20;
              var selectedItem = app.activeDocument.selection[0];
                   newItem.height += radiusIncrease;
                   newItem.width += radiusIncrease;
          All I need is to convert the pixels to centimeters. Does anyone know the best way to achieve this? Thanks.
          • 2. Re: Basic question, duplicating a circle with javascript
            CarlosCanto Adobe Community Professional & MVP
            selection returns an array, so either do either
            or
            newItem = selectedItem[0].duplicate();
            • 3. Re: Basic question, duplicating a circle with javascript
              pixxxel schubser MVP & Adobe Community Professional
              the other way (your script):
                      newItem = selectedItem[i].duplicate();
              • 4. Re: Basic question, duplicating a circle with javascript
                maguskrool Level 1
                Thanks. I got an error using this option, though, not sure why but it says the last item (in this case, selectedItem[i] when i = 2) is undefined.
                • 5. Re: Basic question, duplicating a circle with javascript
                  maguskrool Level 1
                  Thanks for all the help, my code for now is:
                      var newItem;
                      var radiusIncrease = new UnitValue("1 cm").as("px");
                          selectedItem[0] = newItem;
                  All I need now is to center all the circles, but I haven't really delved into that yet, and if I do run into difficulties I'll start a new thread
                  Again, thank you.
                  • 6. Re: Basic question, duplicating a circle with javascript
                    one way to get cm is to use the unitValue object, see a sample usage here
                    http://forums.adobe.com/message/4875863#4875863
                    • 7. Re: Basic question, duplicating a circle with javascript
                      Your script says:
                      When (min) one document is open --> say numberOfItems = 3        //the counter is 3 --> min three or more items should be selected by yourself
                      selectedItem --> is the array of all selected items in document
                      then go for counter = 0 to counter < numberOfItems (means 3-1) -->
                      counter 0 = loop 1 --> duplicate this (item 1 of 3 selected) item
                      counter 1 = loop 2 --> duplicate this (item 2 of 3 selected) item   //when only 1 item is selected by yourself --> result is undefined
                      counter 2 = loop 3 --> duplicate this (item 3 of 3 selected) item   //when only 2 items are selected by yourself --> result is undefined
                      It's equal, how many items are selected by user - but min you have defined here --> var numberOfItems = 3;
                      You need in this example a selection of three items (better: three selected items)
