12 Replies Latest reply on Jan 15, 2015 12:40 PM by andrewrench
    Photoshop (ACS6) dual monitor issues
    ArtRookDesigns Level 1
      Just installed ACS6 and ran updates on a mac book pro and photoshop images look fine on the laptop display, but slide the image to the second monitor, the image turns black. Slide it back and it is fine again. Going to system prefs and change main monitor and the problem is reversed, it is black on the laptop and fine on the second monitor
      Go figure.
        • 2. Re: Photoshop (ACS6) dual monitor issues
          synthview Level 1
          I have the same issue today, after installing the last Photoshop CS6 update this morning. Photoshop is running on a NON retina macbook pro 2.66Ghz Intel core2 duo,
          NVIDIA GeForce 9600M GT (best performance settings).
          EDIT: quitting and reopening Photoshop solved the issue…
          • 3. Re: Photoshop (ACS6) dual monitor issues
            Sam.ux Level 1
            Nice! Had the same problem, but hadn't gotten around to a restart yet. Thanks for the tip.
            • 4. Re: Photoshop (ACS6) dual monitor issues
              rekersting Level 1
              Did you ever find a solution to this problem?
              • 5. Re: Photoshop (ACS6) dual monitor issues
                matchingponies Level 1
                I have many meetings sprinkled through my design time each day so I switch between using a 2nd monitor and just my laptop often. It is extremely annoying to return from a meeting to realize I can't see anything on my large monitor until I close all of my files and restart photoshop.
                Reading this non-solution was icing on the cake. Is this actually getting fixed?
                • 6. Re: Photoshop (ACS6) dual monitor issues
                  jmackler Level 1
                  This is really frustrating.  When will this be fixed.  I had high hopes for the 2014 update, but no dice.  Ahhhhhh!
                  • 7. Re: Photoshop (ACS6) dual monitor issues
                    Jeffrey Tranberry Adobe Employee
                    I can't repro with CC or 2014 on 10.9.3.
                    I wonder if it's card or OS specific.
                    It may help if we could see your Photoshop System Info. Directions for sharing your system info from Photoshop:
                    http://feedback.photoshop.com/photoshop_family/topics/photoshop_how_do_i_share_my_system_i nformation
                    • 8. Re: Photoshop (ACS6) dual monitor issues
                      jmackler Level 1
                      Thanks.  By the way, this happens to the other three people in my office with different monitors and different laptops (all Mac, but some 1-2 years older).
                      Adobe Photoshop Version: 2014.0.0 20140508.r.58 2014/05/08:23:59:59  x64
                      Operating System: Mac OS 10.9.3
                      System architecture: Intel CPU Family:6, Model:70, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                      Physical processor count: 4
                      Logical processor count: 8
                      Processor speed: 2600 MHz
                      Built-in memory: 16384 MB
                      Free memory: 9811 MB
                      Memory available to Photoshop: 14335 MB
                      Memory used by Photoshop: 70 %
                      3D Multitone Printing: Disabled.
                      Touch Gestures: Disabled.
                      Windows 2x UI: Disabled.
                      Image tile size: 1024K
                      Image cache levels: 4
                      Font Preview: Medium
                      TextComposer: Latin
                      Display: 1
                      Main Display
                      High DPI Monitor
                      Display Bounds: top=0, left=0, bottom=1200, right=1920
                      Display: 2
                      Display Bounds: top=-179, left=-2560, bottom=1261, right=0
                      OpenGL Drawing: Enabled.
                      OpenGL Allow Old GPUs: Not Detected.
                      OpenGL Drawing Mode: Advanced
                      OpenGL Allow Normal Mode: True.
                      OpenGL Allow Advanced Mode: True.
                      AIFCoreInitialized=1
                      AIFOGLInitialized=1
                      OGLContextCreated=1
                      glgpu[0].GLVersion="2.1"
                      glgpu[0].GLMemoryMB=2048
                      glgpu[0].GLName="NVIDIA GeForce GT 750M OpenGL Engine"
                      glgpu[0].GLVendor="NVIDIA Corporation"
                      glgpu[0].GLVendorID=4318
                      glgpu[0].GLRectTextureSize=16384
                      glgpu[0].GLRenderer="NVIDIA GeForce GT 750M OpenGL Engine"
                      glgpu[0].GLRendererID=16918311
                      glgpu[0].HasGLNPOTSupport=1
                      glgpu[0].CanCompileProgramGLSL=1
                      glgpu[0].GLFrameBufferOK=1
                      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1638 4]
                      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
                      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                      clgpu[0].CLPlatformVersion="1.2 (Apr 25 2014 22:04:25)"
                      clgpu[1].CLPlatformVersion="1.2 (Apr 25 2014 22:04:25)"
                      clgpu[0].CLDeviceVersion="1.2 "
                      clgpu[1].CLDeviceVersion="1.2 "
                      clgpu[0].CLMemoryMB=1536
                      clgpu[1].CLMemoryMB=2048
                      clgpu[0].CLName="Iris Pro"
                      clgpu[1].CLName="GeForce GT 750M"
                      clgpu[0].CLVendor="Intel"
                      clgpu[1].CLVendor="NVIDIA"
                      clgpu[0].CLVendorID=16925952
                      clgpu[1].CLVendorID=16918272
                      clgpu[0].CLDriverVersion="1.2(May  5 2014 20:39:23)"
                      clgpu[1].CLDriverVersion="8.26.21 310.40.35f08"
                      clgpu[0].CUDASupported=0
                      clgpu[1].CUDASupported=0
                      clgpu[0].CLBandwidth=4.24366e+10
                      clgpu[1].CLBandwidth=4.23843e+10
                      clgpu[0].CLCompute=198.062
                      clgpu[1].CLCompute=45.5154
                      License Type: Subscription
                      Serial number: 94070944098832319724
                      Application folder: /Applications/Adobe Photoshop CC 2014/
                      Photoshop scratch has async I/O enabled
                      Scratch volume(s):
                        Macintosh HD, 931.0G, 452.3G free
                      Required Plug-ins folder: /Applications/Adobe Photoshop CC 2014/Adobe Photoshop CC 2014.app/Contents/Required/Plug-Ins/
                      Primary Plug-ins folder: /Applications/Adobe Photoshop CC 2014/Plug-ins/
                      Installed components:
                         adbeape.framework   adbeape   3.4.0.29366   0.1160850
                         AdbePM.framework.framework   patchmatch   2.0.00.32543   79.554276
                         AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.32394   79.550992
                         adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
                         AdobeACE.framework   AdobeACE   2.20.02.32634   79.554120
                         AdobeAGM.framework   AdobeAGM   4.30.33.32634   79.554120
                         AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.8.0.32260   79.551013
                         AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.8.0.32260   79.551013
                         AdobeBIB.framework   AdobeBIB   1.2.03.32634   79.554120
                         AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.554120
                         AdobeCoolType.framework   AdobeCoolType   5.15.00.32634   79.554120
                         AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
                         AdobeExtendScript.framework   AdobeExtendScript   4.5.5.32401   79.551519
                         AdobeJP2K.framework   AdobeJP2K   1.2.2.32511   79.252744
                         AdobeLinguistic.framework      20256
                         AdobeMPS.framework   AdobeMPS   5.8.1.32565   79.553444
                         AdobeOwl.framework   AdobeOwl   5.0.33   79.552883
                         AdobePDFL.framework   AdobePDFL   11.0.0.32477   79.510482
                         AdobePDFSettings.framework   AdobePDFSettings   1.4
                         AdobePIP.framework   AdobePIP   7.2.1.3399
                         AdobeScCore.framework   AdobeScCore   4.5.5.32401   79.551519
                         AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                         AdobeXMP.framework   AdobeXMPCore   79.155772   79.155772
                         AdobeXMPFiles.framework   AdobeXMPFiles   79.155772   79.155772
                         AdobeXMPScript.framework   AdobeXMPScript   79.155772   79.155772
                         ahclient.framework   ahclient   1.8.0.31
                         aif_core.framework   AdobeAIF   2014.0.00   2014.0
                         aif_ocl.framework   AdobeAIF   2014.0.00   2014.0
                         aif_ogl.framework   AdobeAIF   2014.0.00   2014.0
                         amtlib.framework   amtlib   8.0.0.45
                         boost_date_time.framework   boost_date_time   8.0.0.0
                         boost_signals.framework   boost_signals   8.0.0.0
                         boost_system.framework   boost_system   8.0.0.0
                         boost_threads.framework   boost_threads   8.0.0.0
                         Cg.framework   NVIDIA Cg
                         CIT.framework   CIT   2.2.6.32411   155804
                         CITThreading.framework   CITThreading_boost   2.2.6.32411   155804
                         dvaaudiodevice.framework   dvaaudiodevice   8.0.0.0
                         dvacore.framework   dvacore   8.0.0.0
                         dvamarshal.framework   dvamarshal   8.0.0.0
                         dvamediatypes.framework   dvamediatypes   8.0.0.0
                         dvametadata.framework   dvametadata   8.0.0.0
                         dvametadataapi.framework   dvametadataapi   8.0.0.0
                         dvametadataUI.framework   dvametadataUI   8.0.0.0
                         dvaplayer.framework   dvaplayer   8.0.0.0
                         dvatransport.framework   dvatransport   8.0.0.0
                         dvaui.framework   dvaui   8.0.0.0
                         dvaunittesting.framework   dvaunittesting   8.0.0.0
                         dynamiclink.framework   dynamiclink   8.0.0.0
                         ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                         ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                         LogSession.framework   LogSession   7.2.1.3399
                         mediacoreif.framework   mediacoreif   8.0.0.0
                         PlugPlugExternalObject.framework      5.0.0.62
                         PlugPlugOwl.framework   PlugPlugOwl   5.0.0.74
                         UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
                         WRServices.framework
                      Required plug-ins:
                         3D Studio 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                         Accented Edges 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Adaptive Wide Angle 2014.0, Copyright © 2014 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                         Angled Strokes 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Average 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Average.plugin”
                         Bas Relief 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         BMP 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Camera Raw 8.5 (236), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                         Camera Raw Filter 8.5 (236), Copyright © 2014 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                         Chalk & Charcoal 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Chrome 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Cineon 2014.0.0 x001  ©2002-2014 Adobe Systems Incorporated - from the file “Cineon.plugin”
                         Clouds 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                         Collada DAE 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                         Color Halftone 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Colored Pencil 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         CompuServe GIF 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Conté Crayon 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Craquelure 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Crop and Straighten Photos 2014.0.0 x001  ©2003-2014 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                         Crop and Straighten Photos Filter 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Crosshatch 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Crystallize 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Cutout 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Dark Strokes 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         De-Interlace 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Dicom 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “dicom.plugin”
                         Difference Clouds 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Clouds.plugin”
                         Diffuse Glow 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Displace 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Dry Brush 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Eazel Acquire 2014.0.0 x001  ©1997-2014 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                         Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                         Entropy 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Export Color Lookup 2014.0.0 x001  �2012-2014 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                         Extrude 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         FastCore Routines 2014.0.0 x001  ©1990-2014 Adobe Systems Incorporated - from the file “FastCore.plugin”
                         Fibers 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Film Grain 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Filter Gallery 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Flash 3D 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                         Fresco 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Glass 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Glowing Edges 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Google Earth 4 KMZ 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                         Graphic Pen 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Halftone Pattern 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         HDRMergeUI 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                         IFF Format 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Ink Outlines 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         JPEG 2000 2014.0.0 x001  ©2001-2014 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                         Kurtosis 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Lens Blur 2014.0, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                         Lens Correction 2014.0, Copyright © 2002-2014 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                         Lens Flare 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Liquify 2014.0, Copyright © 2001-2014 Adobe Systems Incorporated - from the file “Liquify.plugin”
                         Matlab Operation 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                         Maximum 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Mean 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Measurement Core 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                         Median 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Mezzotint 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Minimum 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         MMXCore Routines 2014.0.0 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                         Mosaic Tiles 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Multiprocessor Support 2014.0.0 x001  ©1990-2014 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                         Neon Glow 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Note Paper 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         NTSC Colors 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                         Ocean Ripple 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         OpenEXR 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Paint Daubs 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Palette Knife 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Patchwork 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Paths to Illustrator 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         PCX 2014.0.0 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PCX.plugin”
                         Photocopy 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Photoshop 3D Engine 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                         Photoshop Touch CC 2014 (2014.0.0.0) ©1993-2014 Adobe Systems Incorporated - from the file “PSDX.plugin”
                         Picture Package Filter 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                         Pinch 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Pixar 2014.0.0 x001  ©1989-2014 Adobe Systems Incorporated - from the file “Pixar.plugin”
                         Plaster 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Plastic Wrap 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         PNG 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Pointillize 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Polar Coordinates 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Portable Bit Map 2014.0.0 x001  ©1989-2014 Adobe Systems Incorporated - from the file “PBM.plugin”
                         Poster Edges 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Radial Blur 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Radiance 2014.0.0 x001  ©2003-2014 Adobe Systems Incorporated - from the file “Radiance.plugin”
                         Range 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Read Watermark NO VERSION - from the file “DigiRead.plugin”
                         Render Color Lookup Grid 2014.0.0 x001  �2012-2014 Adobe Systems Incorporated - from the file “Export3DLUT.plugin”
                         Reticulation 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Ripple 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Rough Pastels 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Save for Web 2014.0, Copyright © 1999-2014 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                         ScriptingSupport 15.0, Copyright © 2014 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                         Shake Reduction 2014.0, Copyright © 2014 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
                         Shear 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Skewness 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Smart Blur 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Smudge Stick 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Solarize 2014.0.0 x001  ©1993-2014 Adobe Systems Incorporated - from the file “Solarize.plugin”
                         Spatter 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Spherize 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Sponge 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Sprayed Strokes 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Stained Glass 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Stamp 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Standard Deviation 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         STL 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                         Sumi-e 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Summation 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Targa 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Texturizer 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Tiles 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Torn Edges 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Twirl 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Underpainting 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Vanishing Point 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                         Variance 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “statistics.plugin”
                         Water Paper 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Watercolor 2014.0, Copyright © 1991-2014 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                         Wave 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Wavefront|OBJ 2014.0.0 x001  ©2006-2014 Adobe Systems Incorporated - from the file “U3D.plugin”
                         Wind 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                         Wireless Bitmap 2014.0.0 x001  ©1989-2014 Adobe Systems Incorporated - from the file “WBMP.plugin”
                         ZigZag 2014.0, Copyright © 2003-2014 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                      Optional and third party plug-ins: NONE
                      Plug-ins that failed to load: NONE
                      Flash:
                      Installed TWAIN devices: NONE
                      • 9. Re: Photoshop (ACS6) dual monitor issues
                        Thanks. I'm still trying to repro and have asked some other folks on the team to try it as well.
                        • 11. Re: Photoshop (ACS6) dual monitor issues
                          skc45x Level 1
                          This fixed it for me: Using Spaces with dual monitors in OS X Mavericks | Rob Heggen. In the Mission Control Settings, check the box 'Displays have separate Spaces'.
                          • 12. Re: Photoshop (ACS6) dual monitor issues
                            andrewrench Level 1
                            I had the same exact problem shown in the YouTube video but this fixed it for me. But in my case I unchecked that setting. Go figure. At least it works!
