18 Replies Latest reply on May 27, 2016 8:04 AM by resdesign
    Overflow hidden on a rectangle object?
    shadowfax007 Level 1
      I have created a rectangle object with top right and bottom left corners set to 90px.  I have an image that goes inside the box in the bottom left corner.  The problem is I need the box to act as if it is using "Overflow Hidden" so I can position the image in the corner and have it partially "cut off" to fit the corner but It doesn't seem to be working when I set the overflow to hidden on the rectangle.
      Can someone help explain what I'm missing?
      Also (part of my previous post earlier), is there a way to add/change the CSS code generated by Edge without messing anything up?
      I can write this in CSS and add it if I knew where and how (although I'd rather do it within the Edge interface).
      Thanks!
      James
