0 Replies Latest reply on Nov 27, 2007 1:23 AM by Xavi Colomer
    slow Movie, memory leak? Papervision better?
    Xavi Colomer
      Hello people, I'm working in a banner:
      www.fluidtecnik.com/Web/bin/index.html
      This banner is loading images from an XML the first one, in b&w for preview, and the second one the HI-RES image. The movies are getting slow each time an image is loaded. I'd like to add some animations but as I said before, the performance is decreasing constantly.
      I heard about a memory leak, but I don't know how can I solve it.
      first "try-to-be-a-solution": Every time I use a Loader (because is a loop) I check if another Loader with the same name exists, and if exists I remove it.
      second "try-to-be-a-solution": Every time I use a Loader (because is a loop) I check if another Loader with the same name exists, and if exists I cast the content as an Image and I delete the content.
      Any suggestion???
      How Can I improve the performance of Swf (keeping the quality)
      P.S: I've seen some Papervision3d examples. It's possible to get better results than a simple swf (performance - quality)
