1 Reply Latest reply on Jan 15, 2013 4:24 PM by jfb00
    DateFormatter For DataGrid Not Working
    DashawnPD242
      I am currently using flash 4.6 and i am trying to get my dates to format correctly in one of my columns the following codes i am using is below, this doesn't work at all. What am i doing wrong?
      private function formatDate(item:Object, column:DataGridColumn):String
                      var df:DateFormatter = new DateFormatter();
                      df.formatString = "MM/DD/YY";
                      if (column.dataField == "eventdate") {
                          return df.format(item.eventdate);
      and in my DataGrid is
      <s:GridColumn width="90" headerText="Reservation Date"
                                            resizable="true" labelFunction="formatDate"></s:GridColumn>
        • 1. Re: DateFormatter For DataGrid Not Working
          jfb00 Level 3
          Try this:
          private function formatDate(item:Object, dgColumn:DataGridColumn):String
                if(item.hasOwnProperty(dgColumn.dataField) && item[dgColumn.dataField] != null)
                          return formatDate(item[dgColumn.dataField]);
                      else
                          return null;
                      return item[dgColumn.dataField];
                  public function formatDate(val:Date):String
                      var dateFormatter:DateFormatter = new DateFormatter();
                      dateFormatter.formatString = "MM/DD/YYYY";
                      return dateFormatter.format(val);
