6 Replies Latest reply on Jan 12, 2013 11:13 AM by axdeems
    help with a custome scripts
    axdeems Level 1
      Hello! I'm going crazy trying but i wasnt able to figure this out
      My A box is the number of accounts  ( actual number 312 ) this box is a fix number and does not change
      My B box is the accounts remaining for the year
      My C box is the accounts completed during the year
      And up to that point i think im ok im using this for the simple math
      // Get first field value
      var v1 = getField("A").value;
      // Get second field value
      var v2 = getField("C").value;
      // Set this field value equal to the difference
      event.value = v1 - v2;
      Here is my issue  i need to provide a persentage of whats been done but how?  It need to be from 0 to 100% example if we completed 156 the % box should display 50% and when all are completed to be at 100%
      My D changes every week and i dont think this has a solution but since im not sure i'll ask ( d ) box changes every week and we do the math and make the changes  on box c..... ok my question is there any way box d auto add the number type into box c and if i were to delete the number type on d will nop subtract box c *** if that can be done please how???
        • 1. Re: help with a custome scripts
          Custom script for the % completed field
          // Get total accounts for the year
          var v1 = Number(this.getField("A").value);
          // Get completed accounts for the year
          var v2 = Number(thi.getField("C").value);
          // compute the rate of accounts completed
          var CompletionRate = 0;
          // do not divide by zero
          if(v1 != 0) {
          CompletionRate = v2 / v1;
          event.value = CompletionRate;
          Set the format for the field to "Percentage" with 0 decimal places.
          • 2. Re: help with a custome scripts
            axdeems Level 1
            I try just to copy paste but dint work any susgestions ?
            • 3. Re: help with a custome scripts
              Are your sure your field names are correct?
              Are there any errors in the JavaScript console?
              • 4. Re: help with a custome scripts
                axdeems Level 1
                The names are correct and i didnt get any errors! When i copy paste the formula on the custom calculation scripts
                var v1 = Number(this.getField("grand").value);
                var v2 = Number(thi.getField("completed").value);
                if(v1 != 0) {
                Thats the actual formula on the Percentage box
                • 5. Re: help with a custome scripts
                  You left out the setting of the event.value.
                  console.show();
                  console.clear();
                  var v2 = Number(this.getField("completed").value);
                  if(v1 != 0) {
                  console.println("grand value: " + v1);
                  console.println("completed value: " + v2);
                  console.println("% completed: " + util.printf("%,1 0.2f%", (CompletionRate * 100));
                  • 6. Re: help with a custome scripts
                    axdeems Level 1
                    It works...... Thank you so much   you really made my weekend thanks
                    AX
