1 Reply Latest reply on Jan 13, 2013 4:06 PM by ymichel
    Iterate stream indexes to retrieve properties from DynamicStreamItems
    bernb7760
      I am developing an application which takes a given URL and plays the media. I pass a URLResource to a DefaultMediaFactory to create the MediaElement used by the MediaPlayer.
      What I am trying to do is determine the dimensions of the largest of the streams. I would like to set the player to display at this size.
      I am currently trying to do this by registering to receive NUM_DYNAMIC_STREAMS_CHANGE events. In this callback, I use MediaElement.getTrait to retrieve the DynamicStreamTrait. I would iterate through the items in the stream to determine the width and height. However I cannot get dsResource from the DynamicStreamTrait, as it is a private property.
      Could anybody offer me any pointers on how to achieve my aim?
      Thanks, Ben
        • 1. Re: Iterate stream indexes to retrieve properties from DynamicStreamItems
          ymichel Level 1
          The MediaResource is reachable through the MediaElement and the DynamicStreamingItems through the streamItems property :
          var mediaElement:MediaElement = new DefaultMediaFactory().createMediaElement(new URLResource(HDS_STREAM_URL));
          mediaElement.addEventListener(MediaElementEvent.TRAIT_ADD, function (event:MediaElementEvent):void
              if (event.traitType == MediaTraitType.DYNAMIC_STREAM)
                  var dsResource:DynamicStreamingResource = (mediaElement is ProxyElement)
                      ? (mediaElement as ProxyElement).proxiedElement.resource as DynamicStreamingResource
                      : mediaElement.resource as DynamicStreamingResource;
                  for (var dsIndex:int = 0; dsIndex < dsResource.streamItems.length; dsIndex++)
                      if (dsResource.streamItems[dsIndex].width >= MAX_WIDTH)
                          break;
                  var dsTrait:DynamicStreamTrait = mediaElement.getTrait(event.traitType) as DynamicStreamTrait;
                  dsTrait.autoSwitch = false;
                  dsTrait.switchTo(dsIndex);
                  dsTrait.autoSwitch = true;
          var mediaPlayer:MediaPlayer = new MediaPlayer(mediaElement);
          var mediaContainer:MediaContainer = new MediaContainer();
          mediaContainer.addMediaElement(mediaElement);
          addChild(mediaContainer);
