2 Replies Latest reply on Jan 12, 2013 11:39 AM by BKBK
    "Element NAME is undefined in CFLOGIN" error after CF10 upgrade
    cherdt Level 1
      After a recent upgrade from CF9 to CF10 I am seeing the following error in a couple of legacy applications:
      The login code in the Application.cfm looks like this:
      <cfapplication name="SampleApplication"
                clientmanagement="No"
                loginstorage="session"
                sessionmanagement="Yes"
                setclientcookies="No"
                sessiontimeout="#CreateTimeSpan(0, 0, 30, 0)#" />
      <!--- Login --->
      <cflogin applicationtoken="SampleApplication" idletimeout="300">
                <!--- Construct roles --->
                <cfset roles = "" >
                <cfif ListFind( administrators, CFLogin.name ) >
                     <cfset roles = ListAppend( roles, "admin" ) >
                </cfif>
                <cfif ListFind( editors, CFLogin.name ) >
                     <cfset roles = ListAppend( roles, "edit" ) >
                </cfif>
                <!--- If no roles specified, send user up one level --->
                <cfif roles EQ "" >
                     <cflocation url="../index.cfm" addtoken="no" />
                </cfif>
                <!--- Login user --->
                <cfloginuser name="#CFLogin.name#" password="#CFLogin.password#" roles="#roles#" />
      </cflogin>
      Anonymous access is disabled for the directories, so my understanding is that when the CFLogin expires, the <cflogin> block runs again, and that CFLogin.name should be populated with the username supplied by the client. I've just started troubleshooting, but I'm just wondering if anyone else has run into this or has any suggestions.
        • 1. Re: "Element NAME is undefined in CFLOGIN" error after CF10 upgrade
          cherdt Level 1
          I have not been able to reproduce the error since posting this. The above sample code was modified--previously the cfapplication code looked like this:
                    setclientcookies="Yes"
                    sessiontimeout="30" />
          Since loginstorage was not specified, it defaulted to cookies. And obviously the sessiontimeout value was not in the proper format. I suspect that the cflogin idletimeout was triggered, but since the cookie was still present that caused some issue. I'm not positive this is fixed, as users were still reporting issues after this change was made, but those may be lingering effects of the old code. I'll update here once I have verified that the issue is resolved.
          • 2. Re: "Element NAME is undefined in CFLOGIN" error after CF10 upgrade
            BKBK Adobe Community Professional & MVP
            Sessiontimeout="30" has proper format. However it means a timeout of 30 days. Your new value, sessiontimeout="#CreateTimeSpan(0,0,30,0)#", is equivalent to Sessiontimeout="0.02083". That is because 30 minutes is half of one twenty-fourth of a day.
            The error message, "Element NAME is undefined in CFLOGIN", tells you that the login form, with input fields named j_username and j_password, was not submitted as expected. That in turn tells you that your authorization framework is shaky.
            First do a check for the login form. Failure to submit it means the user will be shown the form. You could do something like:
                  <cfif NOT IsDefined("cflogin")>
                        <cfinclude template="loginform.cfm">
                        <cfabort>
                      <cfelse>
                      <cfset roles = "" >
                      </cfif>
                      </cfif>
                      <cfif roles EQ "" >
                      </cfif>
                 </cfif>
            </cflogin>
            Lastly, setclientcookies="no" means you will have to write the code for setting cookies. If you don't, then you should use setclientcookies="Yes".
