7 Replies Latest reply on Jan 10, 2013 12:25 PM by shooternz
    PP 6.0 titler issue
    DSNProducer
      I am having an issue with the Premiere Pro titler.  I create a new still title at 960x720, but when I place it on the timeline, the text size is much larger, and positioning of the text is off from what I set up in the titler window.  Has anyone else had this problem?  I feel sure it's operator error.  Thanks!
        • 1. Re: PP 6.0 titler issue
          Jim_Simon Level 9
          Likely your title size is larger than your sequence size.  Ideally they should match.
          • 2. Re: PP 6.0 titler issue
            DSNProducer Level 1
            Thanks, Jim.  I did check that, and they are.  Funny thing is that if I work with it a little, like move it around, or reopen the title editor, or even click on the title in the timeline, or move it up into the viewer, it will re-size and look fine.
            • 3. Re: PP 6.0 titler issue
              DSNProducer Level 1
              Sometimes, but not always.  I'm sort of stymied on this...
              • 4. Re: PP 6.0 titler issue
                DSNProducer Level 1
                When I create the new title, it asked for a size, and the only choice I have for that ratio is the HD Anamorphic 1080, so maybe that's the problem.  PP seems to select the size for you based on the sequence settings...
                • 5. Re: PP 6.0 titler issue
                  Jeff Bellune Level 5
                  I've had this happen as well.  Is the project from an earlier version of Premiere Pro?  Was the previous title based on a font that isn't on your system anymore?
                  If you change the percentage size of the font from 100% to something else, then return it to 100%, that should fix the size issue.  You may have to re-position the title in the frame as well.
                  Jeff
                  • 6. Re: PP 6.0 titler issue
                    DSNProducer Level 1
                    Thanks, Jeff.  No, project is 6.0.  And fonts I used are all installed, and I'm seeing this on newly-created titles.  I will give the font sizing a try.  Something I'm doing once the title is created is causing it to finally revert to the intended size and position, so I will experiment.  Many thanks!
                    • 7. Re: PP 6.0 titler issue
                      shooternz Level 6
                      Correct...and logical.  Why would one create a title based on a different size than the target sequence setting.
                      If for some reason one might need that...create an appropriate  sequence then create a title based on that.
