4 Replies Latest reply on Jan 16, 2013 3:43 AM by RichP90
    CQ5.2 Taglibs not working
    RichP90
      Our development author node went down today with the following error on every page:
      org.apache.sling.api.scripting.ScriptEvaluationException: org.apache.sling.scripting.jsp.jasper.JasperException: /apps/myApp/components/page/base/base.jsp(1,1) The absolute uri: http://www.day.com/taglibs/cq/1.0 cannot be resolved in either web.xml or the jar files deployed with this application
      It's failing at the setup of the tag libraries in /libs/wcm/global.jsp
      There's nothing we did out of the ordinary, just some standard component edits and then this error. I've searched around for a few hours but can't find anything to solve the issue.
      Any ideas would be gratefully received
        • 1. Re: CQ5.2 Taglibs not working
          Krishna Kancherla
          Sometimes we encounter this error even if there are some errors in your bundles. Check if you all your bundles and components are active.
          • 2. Re: CQ5.2 Taglibs not working
            RichP90 Level 1
            Yes, all bundles are active.
            I have just removed our bundle and all traces of the application from the repository and tried the Geomettrix example pages but still the same error.
            I really don't want to have to create a fresh development instance but can't see another way around it. It is concerning that it can all break so easily.
            • 3. Re: CQ5.2 Taglibs not working
              Krishna Kancherla Level 1
              Can you share log. I will try to see if I can provide any more updates. Not only bundles, check the components as well. Sometimes if components are not active you will get this kind of error.
              • 4. Re: CQ5.2 Taglibs not working
                RichP90 Level 1
                Thanks for your suggestion, the server log showed bundles that were not working properly including cq-wcm-taglib-5.2.0.jar and day-commons-jstl-1.1.2.jar.
                Here's the error messages:
                16.01.2013 10:48:55 *ERROR* webapp-CRX Launchpad Webapp: ERROR: org.apache.felix.framework.cache.BundleCache: Error creating archive. (java.io.FileNotFoundException: D:\CQ5\author\crx-quickstart\launchpad\felix\bundle30\version162.-1\revision.location (The system cannot find the path specified))
                The refresh.counter file contained 162 but the bundle jar was in a folder called version161.0. So, I changed the refresh.counter to 161 and it's all working fine again.
                What can cause this mismatch?
