Back when Audition was Cool Edit Pro, they had an option while adding effects while in Edit Mode that would let you highlight a section of the waveform, add an effect say like an echo, then would allow to process that effect to the end of view. That was a beautiful thing.... Since Adobe took over, that has been missing. I can't believe I was the only one out there that used this option. It was a HUGE time saver!!! Say like I want to add an echo to only one word. I could highlight that word, add the echo, then have the word echo past the highlighted area until it faded completely, or reached the end of the view. Now, I have to highlight that word, cut and paste it into a new track, then go back into edit mode, extend silence to the end of the file, add the echo effect, go back to multitrack mode and then mixdown the 2 files. This is rediculous and time consuming. Am I missing that option somewhere or does it not exist?? Or maybe someone out there has a better way to do it??? Or better yet....ADD THAT OPTION BACK IN!!!!
yes definately this should be added back
