1 Reply Latest reply on Jan 11, 2013 2:54 PM by Flex harUI
    Flex webservice huge performance issue
    PriyaGopinath
      I am pulling  good amount of data using webservice from a java application. The data is a bit complex in its structure with lot of hierarchical pattern using array collections. I am experiencing huge performance issue of around 15 second(in jboss and WebSphere) to get the data loaded. Time consumed is mostly while converting the service data into flex object structure. Issue gets worsen while moving to Weblogic application server. I am using axis2 framework.
      Is there any way to optimize this? What can be the alternative technologies I can use instead of webserivces?
