7 Replies Latest reply on Jan 14, 2013 3:54 AM by Harbs.
    How to change menu position
    Alexander Baranovski Level 1
      I want to place menu item of my Extension to another position of the InDesignMenu. For example  "Windows->Extensions->MyExtension" change to "Windows->MyExtension". I know how I can do this in C++ plug-in. Is it possible for extensions?
      Best regards,
      Alex
        • 1. Re: How to change menu position
          Harbs. Level 6
          Take a look at the getting-started pdf in the SDK docs.
          Chapter 8 has a section on the CS SDK. There's info there on how to do it in the section called "Overriding default menu placement".
          Harbs
          • 2. Re: How to change menu position
            Could you please give link to this pdf. Because at this, I didn't found information:
            http://wwwimages.adobe.com/www.adobe.com/content/dam/Adobe/en/devnet/creativesuite/pdfs/CS _SDK_Guide.pdf
            • 3. Re: How to change menu position
              Harbs. Level 6
              I was referring to the InDesign C++ SDK. If you've developed C++ plugins, I assume you have the SDK...
              • 4. Re: How to change menu position
                Harbs. Level 6
                For sake of completeness (or for those who haven't downloaded the SDK), I'm  pasting the section in here...
                NOTE: Overriding the default menu position is supported by InDesign, but not yet by other Creative Suite
                applications.
                By default, CSXS supports a single main menu item, which appears in the application’s Window >
                Extensions menu. Extension developers may prefer a different menu location. InDesign supports a Menu
                element and Placement attribute in the manifest.xml that allows an extension to override the default
                menu position. For example:
                <Menu Placement="'Main:&amp;Window',600.0,'KBSCE Window menu'">FlexUIStroke</Menu>
                The Placement attribute needs to be created with care. See the FlexuUIStroke code for a more precise
                example (without a line break).
                • Strings must be enclosed in single quotes.
                • Commas (without white space) are used to separate fields.
                Menu path
                The menu path format is similar to the format used by MenuDef ODFRC resources (see also
                IMenuManager.h).
                • Menu path components must either be localizable key strings or be prefixed with the
                kDontTranslateChar (.).
                • The accelerator key must be escaped using &amp; in the menu path. To include an actual ampersand
                character in a menu path component or menu item, use a double ampersand (&&).
                • If the first character in the menu path is a hyphen, InDesign inserts a menu separator before the
                extension’s menu item. Similarly, if the last character is a hyphen, InDesign inserts a separator
                afterwards. Both may be specified.
                • Menu paths must exactly match the key string for existing menus. The easiest way to determine these
                strings is to dump the existing menus in the debug build using Test > UI > Actions > Dump MenuMgr
                info(all). This uses TRACE commands, so you must first set the location of trace output. For example,
                you can set it to trace text into an open copy of Notebook. Search for a string such as “Main:&Window”
                to find menu items that belong to the Window menu.
                Menu position
                The menu position value is identical to the one used by MenuDef ODFRC resources (see also
                IMenuManager.h).
                • To sort a menu item alphabetically, use the same menu position as the other menu item(s).
                • Refer to AdobeMenuPositions.h for predefined menu positions of other menu items.
                ActionArea
                The action area format is identical to the one used by ActionDef ODFRC resources (see also
                IActionManager.h).
                • The action area string must be a localizable key string.
                • Refer to ActionDefs.h for predefined action areas used by other menu items.
                • 6. Re: How to change menu position
                  Thank you, this helps:
                  Best regards,
                  Alex
                  • 7. Re: How to change menu position
                    Harbs. Level 6
                    This is particularly important as well:
                    It'll work without the period prefix, but you're making InDesign search the whole string database before giving up...
                    Harbs
