2 Replies Latest reply on Jan 12, 2013 1:03 PM by weissjeff
    Email
    weissjeff
      I have photoshop elements 11. When I attempt to send a email(using gmail that I set up) after I go to contact at the next screen I cant change the message> i can delete the default message but I cant figure out how to add a new message> Any suggestions?
        • 1. Re: Email
          99jon Adobe Community Professional & MVP
          There is some kind of scripting bug in PSE11 when using photo mail but not attachments. But there is a work around.
          Select your thumbnails and click Share >> Photomail
          Then choose your contact and continue.
          After choosing stationery, click next step.
          In the next dialog (customize & layout) click on the text dropdown and change from Arial to Times New Roman (may not be essential but it works for me).
          Then click next.
          When the email appears you should now be able to select (click until a bounding box appears around the text like that of a picture) and delete all the Adobe automatic text, leaving only the photo(s). Delete the web link and text below the photo using the backspace key. You should now be able to add your own text.
          Then hit send.
          • 2. Re: Email
            weissjeff Level 1
            Thank you. That was very helpful-Jeff
            Sent via BlackBerry by AT&T
