5 Replies Latest reply on Jan 13, 2013 11:39 AM by kglad
    Bracket notation
    TOverturf Level 1
      According to my memory this:
      textData = jsessionLoader.data;
      and this:
      var loaderName:String = "jsessionLoader";
      textData = [loaderName].data;
      Should amount to the same thing, apparently Flash doesn't agree. =P
      What am I doing wrong?
        • 1. Re: Bracket notation
          there's no scope assigned to your array notation.  use:
          textData=this[loaderName].data;  // assuming "this" is the correct scope.
          • 2. Re: Bracket notation
            TOverturf Level 1
            Already tried that, flash throws this error:
            TypeError: Error #1010: A term is undefined and has no properties.
                      at MethodInfo-397()
                      at flash.events::EventDispatcher/dispatchEventFunction()
                      at flash.events::EventDispatcher/dispatchEvent()
                      at flash.net::URLLoader/onComplete()
            Got a quick tip on how I can define/get the scope?
            • 3. Re: Bracket notation
              copy and paste your code showing your loader's data property is defined and the code using a string and array notation trying to access your loader's data.
              • 4. Re: Bracket notation
                TOverturf Level 1
                var fl_TextLoader:URLLoader = new URLLoader();
                var fl_TextURLRequest:URLRequest = new URLRequest("http://google.com");
                function loadSession(loaderText:String):void
                          this[loaderText].addEventListener(Event.COMPLETE, completeHandler);
                          function completeHandler(event:Event):void
                                    trace([loaderText].data);
                          fl_TextLoader.load(fl_TextURLRequest);
                loadSession("fl_TextLoader");
                As soon as I replace trace([loaderText].data) with trace(fl_TextLoader.data) everthing check outs.
                • 5. Re: Bracket notation
                  you are nesting named functions.  that is always problematic.
                  use:
                  var s:String;
                  s=loaderText;
                                      trace(this[s].data);
