1. Re: Photoshop Elements 9 and Adobe Camera RAW 6.6
domnic.rj23 Jan 13, 2013 6:33 PM (in response to bgelfand)In such cases, Update page is normally correct, unless nikon has a special contract with adobe for ACR6.6 installation on PSE9. Did nikon provided you with any special cd containing ACR6.6?
2. Re: Photoshop Elements 9 and Adobe Camera RAW 6.6
R_Kelly Jan 13, 2013 7:22 PM (in response to bgelfand)Actually neither is right.
The camera raw 6.6 plugin won't work in pse 8, but does work in pse 9 if you install it manually.
What operating system would you be working with?
some more about your question:
3. Re: Photoshop Elements 9 and Adobe Camera RAW 6.6
bgelfand Jan 14, 2013 10:24 AM (in response to R_Kelly)Thank you both for your replies.
@domnic.rj23 - I received the copy of PSE 9 from WACOM when I purchased a WACOM tablet. Since I run CS5 on my copmputer, the copy is excess to me. It is not a special copy.
@R_Kelly - She is running Windows Vista SP2..
4. Re: Photoshop Elements 9 and Adobe Camera RAW 6.6
R_Kelly Jan 14, 2013 7:58 PM (in response to bgelfand)After you install photoshop elements 9 on the vista machine follow the steps below to install the camera raw 6.6 plugin:
1. Download the 6.6 DNG Converter and install the profiles:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5310
2. Download the 6.6 camera raw plugin zip file:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=5316
3. Unzip the folder by right clicking on folder and choosing Extract All
4. Inside the extracted folder doulble click on the Payloads folder
5. Then double click on the CameraRawForElements6.4All-011211045300 folder
(should be the second folder with a size of 16.0 mb)
6. Right click on the Assets2_1.zip and choose Extract All
7. Rename the file from 1002 to Camera Raw.8bi
8. Right click on the Camera Raw.8bi and choose Copy
9 Go to:
C:\Program Files (x86)\Common Files\Adobe\Plug-Ins\Elements 9\File Formats (64 bit vista)
or
C:\Program Files\Common Files\Adobe\Plug-Ins\Elements 9\File Formats (32 bit vista)
10. Drag the old camera raw plugin to the Recycle Bin and right click in the empty space in the folder and choose Paste
Start the pse 9 editor and under Help>About Plug-In>Camera Raw should hopefully say version 6.6.
5. Re: Photoshop Elements 9 and Adobe Camera RAW 6.6
bgelfand Jan 15, 2013 10:25 PM (in response to R_Kelly)Thank you very much for the step-by-step instructions, R_Kelly.
6. Re: Photoshop Elements 9 and Adobe Camera RAW 6.6
bgelfand Jan 19, 2013 2:11 PM (in response to R_Kelly)Thank you very much R_Kelly.
It worked perfectly. She processed her first Nikon 1 V1 NEF RAW file aout 1/2 hour ago. The Photoshop Elements 9 Orginizer also shows the NEF files correctly.
