0 Replies Latest reply on Jan 13, 2013 8:25 PM by Emertana
    My flex code does not parse SOAP Response
    Emertana
      I have the following code to populate the drop down box but it does not,
      once the application is run the dropdown box is empty, I used many different methods but neither works. (I deleted the flex generated tags such as declarations for simplicity)
                                       xmlns:mx="library://ns.adobe.com/flex/mx"
                                       xmlns:components="components.*"
                                       xmlns:hellos="services.hellos.*"
                                       height="957"  creationComplete="initApp()" >
          [Bindable]
          public var customers:ArrayCollection;
                   private function initApp():void
                                               myService.mycustomers();
                                    protected function myService_resultHandler(event:ResultEvent):void
                                              customers  = event.result as ArrayCollection;
                   <s:WebService id="myService"
                                         wsdl = "http://localhost:8081/WebServiceTest/services/Hellos?wsdl"
                                         result="myService_resultHandler(event)"/>
               <s:FormItem label="Employee:">
                                    <s:DropDownList id="dropDownList3"
        dataProvider="{customers}"
        labelField="name"/>
               </s:FormItem>
      SOAP response that I found in network monitor is as following
          <?xml version="1.0" encoding="UTF-8"?>
          <soapenv:Envelope
            xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
            xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <soapenv:Body>
              <mycustomersResponse xmlns="http://Services.com">
                <mycustomersReturn>
                  <age>28</age>
                  <name>John</name>
                </mycustomersReturn>
                <mycustomersReturn>
                  <age>29</age>
                  <name>Ryan</name>
              </mycustomersResponse>
            </soapenv:Body>
          </soapenv:Envelope>
