14 Replies Latest reply on Jan 14, 2013 7:32 AM by Harbs.
    JSFL callbacks
    Rahul Kamra Level 1
      Hi ,
      I am using Adobe Extension Builder Plugin for Eclipse to build the extensions for Flash. I also want to use JSFL file in the extension. I included the .jsfl file in the Bundle editor.
      I can call the method of JSFL using CSInterface.instance.evalScript("hello"); and able to get the response of the method. Now i want to call a method form JSFL back to actionscript  which i was not able to do. i tried lots of ways including HostObject API but was not be able to call AS from JSFL .
      Any Ideas?
      Rahul.
        • 1. Re: JSFL callbacks
          Harbs. Level 6
          Here's the basics:
          jsfl:
          function registerExtension(extension){
               kExtensionForCallback = extension;
          function doSomethingInvolvingExtension(){
          // do stuff
          if(kExtensionForCallback){
               kExtensionForCallback.doSomeActionScriptStuff()
          } else {
               throw "woops! no extension registered!"
          ActionScript:
          CSInterface.instance.evalScript("registerExtension", this);
          CSInterface.instance.evalScript("doSomethingInvolvingExtension");
          • 2. Re: JSFL callbacks
            Harbs. Level 6
            Sorry. This is not going to work using evalScript().
            It will work using the HostObject method:
            http://cookbooks.adobe.com/post_Communicating_between_JavaScript_and_the_Creative-17383.ht ml
            • 3. Re: JSFL callbacks
              Rahul Kamra Level 1
              I tried using this also. I got this error
              Error: EvalError: function eval must be called directly, and not by way of a function of another name
                        at TestFlash/appComplete()[D:\Work\Workspace\Extensions\TestFlash\src\TestFlash.mxml:32]
                        at TestFlash/___TestFlash_CSExtension1_applicationComplete()[D:\Work\Workspace\Extensions\Te stFlash\src\TestFlash.mxml:2]
                        at flash.events::EventDispatcher/dispatchEventFunction()
                        at flash.events::EventDispatcher/dispatchEvent()
                        at mx.core::UIComponent/dispatchEvent()[E:\dev\trunk\frameworks\projects\framework\src\mx\co re\UIComponent.as:13128]
                        at mx.managers::SystemManager/preloader_preloaderDoneHandler()[E:\dev\trunk\frameworks\proje cts\framework\src\mx\managers\SystemManager.as:2682]
                        at mx.preloaders::Preloader/displayClassCompleteHandler()[E:\dev\trunk\frameworks\projects\f ramework\src\mx\preloaders\Preloader.as:582]
                        at mx.preloaders::SparkDownloadProgressBar/initCompleteHandler()[E:\dev\hero_private\framewo rks\projects\framework\src\mx\preloaders\SparkDownloadProgressBar.as:1087]
                        at mx.preloaders::Preloader/dispatchAppEndEvent()[E:\dev\trunk\frameworks\projects\framework \src\mx\preloaders\Preloader.as:380]
                        at mx.preloaders::Preloader/appCreationCompleteHandler()[E:\dev\trunk\frameworks\projects\fr amework\src\mx\preloaders\Preloader.as:590]
                        at mx.core::UIComponent/set initialized()[E:\dev\trunk\frameworks\projects\framework\src\mx\core\UIComponent.as:1818]
                        at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\trunk\frameworks\projects\frame work\src\mx\managers\LayoutManager.as:842]
                        at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\trunk\frameworks\projec ts\framework\src\mx\managers\LayoutManager.as:1180]
              • 4. Re: JSFL callbacks
                Harbs. Level 6
                I'm not sure I'm folowing you. What did you try?
                • 5. Re: JSFL callbacks
                  Rahul Kamra Level 1
                  <csxs:CSExtension xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:csxs="com.adobe.csxs.core.*"
                                                            applicationComplete="appComplete()">
                            <fx:Script>
                                      <![CDATA[
                                                [ Embed (source= "test.jsx" , mimeType= "application/octet-stream" )]
                                                private static var myScriptClass:Class;
                                                [Bindable]
                                                private var hostName:String = HostObject.mainExtension;
                                                public function appComplete():void{
                                                          var  jsxInterface:HostObject = HostObject.getRoot(HostObject.extensions[0]);
                                                          jsxInterface.eval(new myScriptClass().toString());
                            </fx:Script>
                  </csxs:CSExtension>
                  and my .jsx file looks like
                  function myJSXFunction(a, b) {
                      return a + b;
                  It thorw error at  jsxInterface.eval(new myScriptClass().toString()); line .
                  • 6. Re: JSFL callbacks
                    Rahul Kamra Level 1
                    Am i missing somthing ?
                    • 7. Re: JSFL callbacks
                      Harbs. Level 6
                      Probably not.
                      Flash CS5 did not support HostObject.
                      I thought CS6 did, but maybe I was wrong.
                      Try jsxInterface.eval("alert('hello')").
                      Does that pop up an alert or give you an error?
                      Harbs
                      • 8. Re: JSFL callbacks
                        Rahul Kamra Level 1
                        Same Error as before,
                        But actually jsxInterface.alert("hello"); worked . Still unsuccessfull with the callbacks
                        • 9. Re: JSFL callbacks
                          Harbs. Level 6
                          Ha!
                          Okay. So it does support HostObject, but Flash does not support eval()...
                          Okay. Here's how to get it to work:
                          1) First use evalScript() to create your functions.
                          function init(){
                               gMyScriptInterface = function(){};
                               gMyScriptInterface.registerExtension = function(extension){
                                    gMyScriptInterface.extension = extension;
                          2) jsxInterface.gMyScriptInterface.registerExtension(this);
                          • 10. Re: JSFL callbacks
                            Rahul Kamra Level 1
                            This is what i did.
                            JSFL File
                            function hello(){
                                 alert('hello');
                            Try 1:
                            [ Embed (source= "test.jsfl" , mimeType= "application/octet-stream" )]
                            I embed the .jsfl file in the MXML and then i can use CSInterface.instance.evalScript(new myScriptClass().toString())
                            Error: EvalScript: Failed to evaluate script for engine <com.example.TestFlash.extension1_Engine_Id>
                            Try 2:
                            I included the JSFL in the package without embeding . Using this i am able to call  CSInterface.instance.evalScript("hello");
                            • 11. Re: JSFL callbacks
                              Harbs. Level 6
                              Use your method in try 2, but add a function to register your extension.
                              DO NOT embed or use
                              Call your register function directly using
                              You should then be able to address your extension using
                              gMyScriptInterface.extension.doSomething() fromt your jsfl script.
                              • 12. Re: JSFL callbacks
                                Rahul Kamra Level 1
                                I entore post got deleted  , let me write it again
                                • 13. Re: JSFL callbacks
                                  Rahul Kamra Level 1
                                  This is what i did.
                                  JSFL File
                                  function hello(){
                                       alert('hello');
                                  Try 1:
                                  Try 2:
                                  I included the JSFL in the package without embeding . Using this i am able to call  CSInterface.instance.evalScript("init");
                                  So i tried to changed my JSFL code and tried to pass the param
                                  var x;
                                  function init(param){
                                            x = paraml
                                  and modified the AS code to
                                            CSInterface.instance.evalScript("init",this);
                                  Error: Invalid Input Parameters
                                  Try 3:
                                  Now i used a mixed way ( as mentoined by you ) keeping the same JSFL but changing the AS code
                                  AS Code :
                                  var esi:HostObject = HostObject.getRoot( HostObject.mainExtension);
                                  esi.init(this);
                                  Error : FlashPro encountered a fatal exception , FlashPro will now terminate.(I have no idea why my 2 lines of extension made the FlashPro crash).
                                  Try4:(I dont know why i dont give up)
                                  JSFL Code:
                                  var x;
                                            x = param;
                                  function test(){
                                            x.callB();
                                  AS :
        ExternalInterface.addCallback("callB",callB);
        esi.__set("x",this);
        CSInterface.instance.evalScript("test");
                                            public function callB():void{
        trace("test");
                                  Error: Invalid ActionScript wrapper object , Line (CSInterface.instance.evalScript("test");)
                                  However in this version i was able to set the value of x in JSFL but still was not able          get a callback
                                  • 14. Re: JSFL callbacks
                                    Harbs. Level 6
                                    Try 3 was very close.
                                    This:
                                    should be:
                                    var esi:HostObject = HostObject.getRoot(HostObject.extensions[0]);
                                    But, when I try this, Flash crashes. I'm not sure what's going on.
                                    I don't really have time to spend on this now...
