4 Replies Latest reply on Jan 14, 2013 12:29 PM by resdesign
    How to remove a loaded image on the stage from a symbol containing a button?
    resdesign Adobe Community Professional & MVP
      1st the setup:
      1. General map is loaded
      2. On a click event, an larger image of the region is loaded with the following code (thanks to Joel's demo). On mouseover the name of the county appears and on click a popup (symbol) shows some info.
      $('<img id="region1" width="310" height="475" src="images/region1.png" usemap="#region1">'+'<map name="region1">'+...
      '<area id="Dallam" shape="rect" title="Dallam" coords="29,17,97,58"/>'+.....
      3. In the popup symbol, I want the large image map to be remove on the click event of the button: "View another region" . I have the following code which does not work (the image is not removed) resulting in what you see below:
      sym.playReverse();
      sym.getComposition().getStage().stop(0);
      sym.getComposition().getStage().getElementById("region1").remove();
      So my question is how do I remove the image (large image of the region in purple here loaded as described on 2.)?
