5 Replies Latest reply: Jan 15, 2013 8:55 AM by RoboColum(n) RSS
    Webhelp display in Firefox does not use stylesheet.
    AMCGracer Community Member
      I have created a Webhelp system using Robohelp, single-sourced from FrameMaker.
      I have a custom stylesheet (CSS) file that I am deploying with the Webhelp.
      On IE and Chrome, the stylesheet is used.
      On Firefox, it is not.
      Does anyone know why this might occur?
        • 1. Re: Webhelp display in Firefox does not use stylesheet.
          RoboColum(n) MeganK
          I suspect that the style sheet IS being used by FF but that there is some element that is not being rendered correctly. Can you give us some more infomation to go on, perhaps with an image or two to see what you are?
          • 2. Re: Webhelp display in Firefox does not use stylesheet.
            Here is a screen shot of the help displayed in Chrome.
            Now here it is in Firefox
            The most obvious difference is the font.
            Does this give you any idea?
            Thank you so much for your help!
            • 3. Re: Webhelp display in Firefox does not use stylesheet.
              RoboColum(n) MeganK
              Not much of an idea at the moment. Are you sure that the relevant styles have been applied to the topic title and text? Is it just this one topic that is affected or all topics? Perhaps you could paste a bit of the XHTML code for us to see.
              • 4. Re: Webhelp display in Firefox does not use stylesheet.
                All topics are affected in the same way. In Firefox, it looks like the default HTML styles are applied.
                I'm not sure what source you are looking for in particular, but I've done a view source copy/pasted from both browsers. (I don't see an obvious difference) Is this what you need?
                I noted the extra line above the <HTML> tag and thought that Firefox might be choking on it, but I deleted that blank line and reloaded, but got the same results.
                Firefox
                <html>
                <head>
                <link rel="shortcut icon" href="whstart.ico">
                <title>Help for VTM Enterprise</title>
                <meta name="generator" content="Adobe RoboHelp 9" />
                <meta name="description" content="WebHelp 5.50" />
                </head>
                <script type="text/javascript" language="javascript" src="whver.js"></script>
                <script type="text/javascript" language="javascript" src="whutils.js"></script>
                <script type="text/javascript" language="javascript" src="whmsg.js"></script>
                <script type="text/javascript" language="javascript" >
                if (!window.gbWhVer||!window.gbWhUtil||!window.gbWhMsg)
                document.location.reload();
                </script>
                <script type="text/javascript" language="javascript" src="whstub.js"></script>
                <script language="javascript">
                var nWebhelpNavPaneMode = 1; //1: DHTML 2:PureHTML 3:Noframe At all
                var strPaneDHTML = "whskin_pdhtml.htm"; //whd_nvp10.htm if tab enabled, whnframe.htm if tab disabled.
                var strPaneList = "whskin_plist.htm";
                var strPane = "";
                var nViewFrameType = -1;
                if (!window.gAgent)
                // low end browser, we don't even try to determine it.
                document.location = "whnjs.htm";
                else
                if (!gbNav4&&!gbIE4&&!gbOpera7&&!gbSafari)
                else if (gbNav4 && !gbNav6 && ((gnVerMinor
                <= 4.06)))
                else if (gbMac && gbIE4 && !gbIE5)
                //figure out which mode is the best
                else
                nViewFrameType=nWebhelpNavPaneMode;
                if (nWebhelpNavPaneMode==1)
                var gbDHTML=(nWebhelpNavPaneMode==1);
                if (gbNav4&&(gnVerMinor
                < 4.1)) nViewFrameType = 2;
                if (gbNav4&&(gnVerMinor == 4.6)) nViewFrameType = 2;
                if (gbIE4&&gbDHTML) nViewFrameType = 1;
                if (gbIE4&&gbSunOS&&nWebhelpNavPaneMode==2) nViewFrameType = 2;
                if (gbNav4&&gbSunOS&&nViewFrameType==2) nViewFrameType = 2;
                if (gbNav6&&gbDHTML) nViewFrameType = 1;
                if (gbMac) nViewFrameType = 2;
                if (gbMac && gbNav6) nViewFrameType = 1;
                if (gbSafari3) nViewFrameType = 1;
                if (nViewFrameType!=-1)
                var gbWindows = ((gAgent.indexOf("win") != -1) || (gAgent.indexOf("16bit") != -1));
                //The colordepth of the 16 color on Windows is 1.
                if ((gbWindows) && (gbNav4) && (window.screen) && (window.screen.colorDepth
                <= 4))
                alert("WebHelp has detected that your display is set to 16 colors. For full WebHelp support, please set your display to use 256 or more colors.");
                nViewFrameType = 2;
                //figure out which one is navpane
                // ReplaceMark:nViewFrameType = 1
                if (nViewFrameType == 1)
                if (gbNav4 && !gbNav6)
                strPane = strPaneList;
                else
                strPane = strPaneDHTML;
                else
                </script>
                <script type="text/javascript" language="javascript" src="whstart.js"></script>
                <script type="text/javascript" language="javascript">
                if (!gbIE4&&!gbNav4&&!gbOpera7&&!gbSafari)
                function CMRAgent( strID, strURL, strLabel, strFrameAttr )
                  this.m_strID = strID;
                  this.m_strURL = strURL;
                  this.m_strLabel = strLabel;
                  this.m_strFrameAttr = strFrameAttr;
                function CMRServer()
                  this.m_cAgents = new Array;
                var cMRServer = new CMRServer;
                // GetServerInfo
                // Registry the agent array handled by webhelp
                // ReplaceMark:MRServer.strServerData
                </script>
                var strHTML = "
                <frameset rows=\"33,*\" hostof=\"parent:toolbar!startpage:yes\" frameborder=\"0\" border=\"0\"> <frame src=\"whskin_tbars.htm\" id=\"toolbar\" frameborder=\"0\" border=\"0\" scrolling=\"no\" noresize=\"\" marginheight=\"0\" marginwidth=\"0\" title=\"Toolbar\"></frame> <frame src=\"whskin_frmset01.htm\" frameborder=\"1\" border=\"1\" scrolling=\"auto\" marginheight=\"0\" marginwidth=\"0\"></frame></frameset>";
                document.write(strHTML);
                </script>
                <frameset cols="100%,*" frameborder=no border=0>
                  <frame src="whnjs.htm">
                  <frame src="whskin_blank.htm" noresize>
                </frameset>
                </html>
                Chrome
                <html>
                <head>
                </head>
                </script>
                var strPane = "";
                if (!window.gAgent)
                else
                else if (gbNav4 && !gbNav6 && ((gnVerMinor <= 4.06)))
                else
                if (gbNav4&&(gnVerMinor < 4.1)) nViewFrameType = 2;
                if ((gbWindows) && (gbNav4) && (window.screen) && (window.screen.colorDepth <= 4))
                nViewFrameType = 2;
                else
                else
                </script>
                // GetServerInfo
                </script>
                var strHTML = "<frameset rows=\"33,*\" hostof=\"parent:toolbar!startpage:yes\" frameborder=\"0\" border=\"0\"> <frame src=\"whskin_tbars.htm\" id=\"toolbar\" frameborder=\"0\" border=\"0\" scrolling=\"no\" noresize=\"\" marginheight=\"0\" marginwidth=\"0\" title=\"Toolbar\"></frame> <frame src=\"whskin_frmset01.htm\" frameborder=\"1\" border=\"1\" scrolling=\"auto\" marginheight=\"0\" marginwidth=\"0\"></frame></frameset>";
                </script>
                </frameset>
                </html>
                • 5. Re: Webhelp display in Firefox does not use stylesheet.
                  RoboColum(n) MeganK
                  I think that is the code for the frameset you are displaying the WebHelp in. What I wanted was the code inside your RoboHelp topic. Click on the HTML tab and paste the code in here.
