1. Re: Book Page numbers in PDF - CS5.5 error
P Spier Jan 14, 2013 9:26 AM (in response to HSGROW_HK)Try trashing your prefs. See Replace Your Preferences
I'm not aware of any general problem with export from CS5.5.
2. Re: Book Page numbers in PDF - CS5.5 error
HSGROW_HK Jan 14, 2013 9:31 AM (in response to P Spier)Hi Peter,
Thanks for the suggestion, I have done that, but still the same .
3. Re: Book Page numbers in PDF - CS5.5 error
P Spier Jan 14, 2013 9:35 AM (in response to HSGROW_HK)Do you have any third-party plugins?
4. Re: Book Page numbers in PDF - CS5.5 error
HSGROW_HK Jan 14, 2013 2:39 PM (in response to P Spier)Hi Peter,
No third-party plug-ins installed. Only plug-ins installed are those what came packaged on the Adobe DVD.
5. Re: Book Page numbers in PDF - CS5.5 error
P Spier Jan 14, 2013 2:44 PM (in response to HSGROW_HK)Font Manager?
6. Re: Book Page numbers in PDF - CS5.5 error
HSGROW_HK Jan 14, 2013 2:47 PM (in response to P Spier)what do you mean?
7. Re: Book Page numbers in PDF - CS5.5 error
P Spier Jan 14, 2013 2:51 PM (in response to HSGROW_HK)Do you use a font manager?
8. Re: Book Page numbers in PDF - CS5.5 error
HSGROW_HK Jan 14, 2013 2:55 PM (in response to P Spier)No, no font manager, I only use Font Book on OSX Mountain Lion. Pretty standard - nothing extraordinary.
9. Re: Book Page numbers in PDF - CS5.5 error
P Spier Jan 14, 2013 3:05 PM (in response to HSGROW_HK)At this point I'm basically stumped.
There are two things you might want to try to see if we can get more of an indication of where the problem is. Fisrtw ould be to create a new user on your Mac, log in with that account, and try the export. The second would be to start ups in "safe mode" by holding down the shift key while your Mac starts up, then try the export before you start any other programs.
10. Re: Book Page numbers in PDF - CS5.5 error
HSGROW_HK Jan 15, 2013 12:14 AM (in response to P Spier)Created new user, same result in normal boot mode. In safe mode, no observable change. Rebooted again and logged on to original logon - same result, no change.
11. Re: Book Page numbers in PDF - CS5.5 error
P Spier Jan 15, 2013 3:55 AM (in response to HSGROW_HK)I'm out of ideas.
12. Re: Book Page numbers in PDF - CS5.5 error
peter at knowhowpro Jan 15, 2013 5:09 AM (in response to HSGROW_HK)HSGROW_HK wrote:
Considering that it's not a problem in InDesign CS6, have you tried opening the CS5.5 project's INDD as well as IDML versions in ID CS6, then exporting as IDML and opening it in InDesign CS5.5 to see if the problem persists? Not sure what changes might occur in the document's text flow, etc, from this round trip.
Is there a compelling reason not to complete the project in InDesign CS6?
HTH
Regards,
Peter
_______________________
Peter Gold
KnowHow ProServices
13. Re: Book Page numbers in PDF - CS5.5 error
HSGROW_HK Jan 15, 2013 4:15 PM (in response to peter at knowhowpro)Hi Peter,
Following your advice, I have tried
The result was the same. The page numbers on the individual pages is fine, the page numbers in the navigation field (as shown in the picture above) contained the errors shown. As for creating in CS6 completely, I would love to but at this stage cannot afford the upgrade! As said, the file will eventually be 300 pages and contain lots of embedded EPS graphs and charts and some photos, making it not practical (size wise) to send to my colleage (who is on the other side of the world) to produce.
14. Re: Book Page numbers in PDF - CS5.5 error
peter at knowhowpro Jan 16, 2013 12:32 AM (in response to HSGROW_HK)If you're in business, you should consider finding a way to afford upgrading the tools you need. I understand that in this case, you're happy with the tools you have, except for a bug that's got you stymied. If there's no unwanted change when opening the project in InDesign CS6, one option would be to wait until the project is ready for final production, then install the 30-day trial of ID CS6, and use it to complete the project. Another option would be to subscribe to the Creative Cloud for one month.
HTH
Regards,
Peter
Peter Gold
KnowHow ProServices
HSGROW_HK wrote:
Hi Peter,
