3 Replies Latest reply on Jan 14, 2013 2:50 PM by Sitaga214
    cfloop not looping as expected
    Leonard B
      Hello,
      CF = 8
      DB = MySQL
      Scenario:
      There are 43 employees who must complete quarterly required training. There are 12 first quarterly items to complete.
      I am attempting to load each of the required quarterly training items respective to each employee number, so that
      subsequent reporting can determine what required training has not been completed by each employee.
      Below is the code I have so far. When this is ran, it loops through the rsEmployeeNumber query and inserts 43
      quarterly training records. However, it is only picking up the first record of the rsQuarterlyTraining and not the
      subsequent 11 records.
      Final Goal:
      To query the required quarterly training requirements for a given employee and in this case display the 12
      quarterly training items for the first quarter of 2013 to see what has or has not been completed.
      What am I missing with my process?
      <cfquery name="rsEmployeeNumber" datasource=""> <== 43 records
          SELECT
              record_id, last_name, first_name, emp_id, emp_id_old, assigned_shift, password, administration, emp_rank, access_group, access_status, email_address, login, exp_date, site_management, training_records, med_cert_level, med_registry_number, manage_training_events
          FROM
              personnel
          WHERE
              assigned_shift = <cfqueryparam cfsqltype="cf_sql_varchar" value="A"> or
              assigned_shift = <cfqueryparam cfsqltype="cf_sql_varchar" value="B"> or
              assigned_shift = <cfqueryparam cfsqltype="cf_sql_varchar" value="C">
      </cfquery>
      <cfloop query="rsEmployeeNumber">
      <cfquery name="rsQuarterlyTraining" datasource=""> <== 12 records
          SELECT RecordID, QuarterYear, QuarterNumber, TrainingGroup, GroupCode, MaterialType, TrainingTitle, TrainingCode, TrainingFile
          FROM
              to_quarterly_training_test
          WHERE
              QuarterYear = <cfqueryparam cfsqltype="cf_sql_integer" value="2013"> and
              QuarterNumber = <cfqueryparam cfsqltype="cf_sql_integer" value="1"> and
              MaterialType = <cfqueryparam cfsqltype="cf_sql_varchar" value="Training">
      </cfquery>
      <cfquery name="rsUploadTraining" datasource=""> <== Should insert 516 records
      Insert Into training_completed_required_test (
          trng_year
          , trng_quarter
          , trng_title
          , emp_id)
      Values (
            <cfqueryparam cfsqltype="cf_sql_integer" value="#rsQuarterlyTraining.QuarterYear#">
          , <cfqueryparam cfsqltype="cf_sql_integer" value="#rsQ2uarterlyTraining.QuarterNumber#">
          , <cfqueryparam cfsqltype="cf_sql_varchar" value="#rsQuarterlyTraining.TrainingTitle#">
          , <cfqueryparam cfsqltype="cf_sql_varchar" value="#rsEmployeeNumber.emp_id#">
      </cfquery>
      </cfloop>
        • 1. Re: cfloop not looping as expected
          Sitaga214
          Did you mean to loop though the rsQuarterlyTraining on the insert?
          If so you need to add a
          <cfloop query="reQuarterlytraining"> above the cfquery insert tag:
              FROM
              WHERE
          </cfquery>
          <cfloop query="rsQuarterlyTraining">
              trng_year
              , trng_quarter
              , trng_title
              , emp_id)
          Values (
          </cfquery>
          </cfloop>
          </cfloop>
          /bill
          • 2. Re: cfloop not looping as expected
            Leonard B Level 2
            Thanks Bill,
            I knew it had to be something simple. Sometimes a person just stares too much at something - lol.
            Leonard B
            • 3. Re: cfloop not looping as expected
              Sitaga214 Level 1
              Glad it was helpful!  Good luck!
