2 Replies Latest reply on Jan 14, 2013 4:29 PM by Dan Bracuk
    Increment a Hidden Column value by +1 each time..
    jlig Level 1
      I have the following code segment & need to add in a third column called ttcount that needs incremented by "1"
      - It always starts out with a value of "1" (when a ticket is created..)
      - If/when that ticket is "Re-Opened", it needs incremented by +1
      so, the question is how to alter the code below to update the ttcount field by 1?
      <!--- Hold off doing the Update unless the the form has been submitted --->
      <cfif isdefined("form.KT_Insert1")>
      <!--- Update the Status to Re-Opened and Owner to Unassigned in the tbltickets table --->
            <cfquery datasource="care">
          UPDATE tbltickets
      SET ttstatus=<cfqueryparam value="Re-Opened" cfsqltype="cf_sql_varchar">,
          ttowner=<cfqueryparam value="Unassigned" cfsqltype="cf_sql_varchar">
      WHERE ttNum=<cfqueryparam cfsqltype="cf_sql_varchar" value="#url.id#">
        </cfquery>
      </cfif>
      Note: the ttcount field is a hidden field as follows:
      <input type="hidden" name="ttcount" id="ttcount" value="1" />
        • 1. Re: Increment a Hidden Column value by +1 each time..
          jlig Level 1
          I figured this out using the following code in bold:
              UPDATE tbltickets
             , ttcount=<cfif IsDefined("FORM.ttcount") AND #FORM.ttcount# NEQ "">
          <cfqueryparam value="#FORM.ttcount#" cfsqltype="cf_sql_numeric">+1
          <cfelse>
          NULL
          </cfif>
            </cfquery>
          </cfif>
          • 2. Re: Increment a Hidden Column value by +1 each time..
            Dan Bracuk Level 5
            There is an easier way.
            UPDATE tbltickets
            ,    ttowner=<cfqueryparam value="Unassigned" cfsqltype="cf_sql_varchar">
            , ttcount = ttcount + 1
