0 Replies Latest reply on Jan 14, 2013 8:21 PM by Emertana
    how to handle soap responses
    Emertana
      I am following this tutorial to handle SOAP responses but it does not work http://livedocs.adobe.com/flex/3/html/help.html?content=data_access_6.html
      using code blew I am trying to parse the following soap response.
                                           xmlns:mx="library://ns.adobe.com/flex/mx"
                                           xmlns:components="components.*"
                                           xmlns:hellos="services.hellos.*"
                                           height="957"  creationComplete="initApp()" >
                    <fx:Style source="Styles.css"/>
                    <fx:Script>
                              <![CDATA[
                                        import mx.controls.Alert;
                                        private namespace invesbot = "http://Services.com";
                                        use namespace invesbot;
                                        private namespace a = "http://schemas.xmlsoap.org/soap/envelope/";
                                        private namespace b = "http://www.w3.org/2001/XMLSchema";
                                        private namespace c = "http://www.w3.org/2001/XMLSchema-instance";
                                        use namespace a;
                                        use namespace b;
                                        use namespace c;
                                        [Bindable]
                                        var _result:*
                                        private function initApp():void
                                                  myService.mycustomers();
                    </fx:Script>
                    <fx:Declarations>
                              <mx:WebService id="myService" wsdl="http://localhost:8081/WebServiceTest/services/Hellos?wsdl"
                                                               showBusyCursor="true"
                                                               fault="Alert.show(event.fault.faultString), 'Error'">
                                        <mx:operation name="mycustomers" resultFormat="e4x">
                                                  <mx:request>
                                                  </mx:request>
                                        </mx:operation>
                              </mx:WebService>
                    </fx:Declarations>
          <mx:HBox>
                              <mx:Text
                                        text="{myService.mycustomers.lastResult.mycustomersReturn.name}"
                    </mx:HBox>
          </s:Application>
      The SOAP response is as following
          <?xml version="1.0" encoding="UTF-8"?>
          <soapenv:Envelope
            xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
            xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
            <soapenv:Body>
              <mycustomersResponse xmlns="http://Services.com">
                <mycustomersReturn>
                  <age>28</age>
                  <name>John</name>
                </mycustomersReturn>
                <mycustomersReturn>
                  <age>29</age>
                  <name>Alex</name>
                <mycustomersReturn>
                  <age>30</age>
                  <name>Jack</name>
              </mycustomersResponse>
            </soapenv:Body>
          </soapenv:Envelope>
      Using the above code the output will be
          <name xmlns="http://Services.com" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">John</name>
          <name xmlns="http://Services.com" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">Alex</name>
          <name xmlns="http://Services.com" xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">Jack</name>
      but when I use the following code to put the result in dropdown box it gives the following error
          <s:FormItem label="Employee:">
                              <s:DropDownList id="dropDownList3"
        labelField="name"
        dataProvider ="{myService.mycustomers.lastResult.mycustomersReturn}"/>
                    </s:FormItem>
      TypeError: Error #1034: Type Coercion failed: cannot convert XMLList@106e9af1 to mx.collections.IList.
