4 Replies Latest reply on Jan 16, 2013 2:34 AM by Bill joy
    How to put a 'gap' between pages in a spread ?
    Bill joy
      I want to put a gap between pages in a spread
      I use reframe method to set gap but X position of  page not change. It is connected with first page.
      It reduce the width of first page not set gap between page.
      var myPages = myDocument.pages;
          //Make the page one inch wider and one inch higher.
          var myPage = myPages.item(1);
          var myBounds = myPage.bounds;
          var myY1 = myBounds[0];
          var myX1 = myBounds[1] + 30;
          var myY2 = myBounds[2];
          var myX2 = myBounds[3];
          myPage.reframe(CoordinateSpaces.INNER_COORDINATES, [[myX1, myY1], [myX2, myY2]]);
      How  put gap between page on a spreade ?
        • 1. Re: How to put a 'gap' between pages in a spread ?
          Jump_Over Level 5
          The question is what is the gap introduced for?
          I.e. if your goal is to include additional area for cover (to make it wider then content)
          I suggest to create a new masterPage (as wide as a gap suppose to be).
          So your spread could be built alike:
          masterPage A - masterPage GAP - masterPage B
          rgds
          • 3. Re: How to put a 'gap' between pages in a spread ?
            Marc Autret Level 4
            Hi Bill,
            Maybe you could simply apply a translation to the pages—since ID CS5 and later supports page transformation.
            For example:
            // NOTE: This won't work with facing-page docs
            var X_GAP = 50, // in points
                CS_INNER = +CoordinateSpaces.INNER_COORDINATES;
            // Example with the 1st spread
            var spd = app.activeDocument.spreads[0],
                pages = spd.pages.everyItem().getElements(),
                n = pages.length,
                i;
            for( i=1 ; i < n ; ++i )
                pages[i].transform(
                    CS_INNER,            // consider the inner bounding box
                    [0,0],                // arbitrary location (translation disregards origin)
                    [1,0,0,1,i*X_GAP,0]    // x-translation by i*X_GAP
            Not sure that answers your question.
            Marc
            • 4. Re: How to put a 'gap' between pages in a spread ?
              Bill joy Level 1
              Thanks to All for reply
              I set gap between spread page using this :
              #target indesign
                var myDocument = app.documents.add();
                myDocument.documentPreferences.facingPages = false;
                myDocument.documentPreferences.allowPageShuffle = false;
                myDocument.spreads.item(0).allowPageShuffle = false;
                var pages= myDocument.pages.add();
                        var myY1 = 0;
                        var myX1 = 594.953;
                        var myY2 = 841.698;
                        var myX2 = 1190.44;
                        pages.reframe(CoordinateSpaces.INNER_COORDINATES, [[myX1 , myY1], [myX2 ,myY2]]);
              If i do not set facingPages = false then it set next page just after first page and i was not able to set X coordinate of second page on first spread.
              Thanks to All.
