4 Replies Latest reply on Jan 18, 2013 7:14 AM by magnesiumpulver
    How to add an effect again (or effects with similar outcome) or "merge effects"?
    magnesiumpulver
      May I bother you with a question?
      Can I add the same effect twice? OR can I "merge layers", similar to PS, then add a new batch of effects?
      I have experienced the same problem a couple of times, here is an example:
      1. I stabilize my clip (by motion tracking including rotation. dozens of keyframes are added to the transformation->rotation of the layer)
      2. The result is crooked and I want to rotate it.
      3. The only (very bad) options I see: edit each keyframe, by adding my -5°; or rendering it and editing it again
      I had the same problem with plug-ins that have effect e.g. on transformation. Once I use it, the former settings are overwritten.
      I guess there is a simple answer I should be able to find in the FAQ's or tutorials, but after 2 hours I'm either blind or a fool. Could you please help me?
      greez
      magnesiumpulver
      _________________
      I'm relatively new to AE but have PS experience. Win7, CS5, 1080p, 8GB, i5,
