7 Replies Latest reply on Jan 16, 2013 7:05 AM by kglad
    as2 predicted trajectory
    pa-pavel Level 1
      I found and managed to adapt this code:
      shoot(); function shoot() {     bulletSpeed = 6;     bullet.gravity = 0.3;     xd = trgt._x-gun._x;     yd = trgt._y-gun._y;     dist = Math.sqrt(xd*xd+yd*yd);     flight = Math.ceil(dist/bulletSpeed);     bullet._x = gun._x;     bullet._y = gun._y;     bullet.xStep = xd/flight;     bullet.yStep = yd/flight;     bullet.yStep -= flight*bullet.gravity/2;     bullet._visible = true; } this.createEmptyMovieClip("lineobj", getNextHighestDepth()); lineobj.lineStyle(5,0xCD1B83,100); lineobj.moveTo(gun._x,gun._y); bullet.onEnterFrame = function() {           lineobj.lineTo(bullet._x,bullet._y);     with (this) {         _x += xStep;         _y += yStep;         yStep += gravity;         if (_root.trgt.hitTest(_x, _y, true)) {             xStep = 0;             yStep = 0;             gravity = 0;             _visible = false;         }     } };
      Now I am trying to get the trigectory line to be drawn befor the 'bullet' shoots, showing where its goiing to land and its arch.
      Any ideas?
      Thx pavel
        • 1. Re: as2 predicted trajectory
          paste formatted code into the forums so it's readable:
          this.createEmptyMovieClip("lineobj",getNextHighestDepth());
          var trajectoryI:Number;
          paramsF();
          initTrajectoryF();
          function paramsF() {
              bulletSpeed = 6;
              bullet._x = gun._x;
              bullet._y = gun._y;
          function initTrajectoryF():Void {
              updateTrajectoryF();
          function updateTrajectoryF():Void {
              bullet._x += bullet.xStep;
              bullet._y += bullet.yStep;
              bullet.yStep += bullet.gravity;
              if (_root.trgt.hitTest(bullet._x, bullet._y, true)) {
                  bullet.xStep = 0;
                  bullet.yStep = 0;
                  bullet.gravity = 0;
                  bullet._visible = false;
                  clearInterval(trajectoryI);
              } else {
          • 2. Re: as2 predicted trajectory
            pa-pavel Level 1
            Thank you so so so much! You are a gunius!
            If I still need help with something else but relating to this should I open a new discussion or ask here?
            gun.onMouseDown = function()
                      if(_ymouse < gun._y)
                                trgt._x = 400
                                trgt._y = 280
                      else if(_ymouse > gun._y)
                                trgt._x = 380
                                trgt._y = 350
                      //shoot();
            If I add the code above how to I ge the trigectory line to adjust on the movement and draw a new line?
            • 3. Re: as2 predicted trajectory
              call paramsF() and initTrajectoryF():
                                  trgt._x = 400
                                  trgt._y = 280
                                  trgt._x = 380
                                  trgt._y = 350
              paramsF();
              initTrajectoryF();
              • 4. Re: as2 predicted trajectory
                pa-pavel Level 1
                Gives me this error:
                256 levels of recursion were exceeded in one action list.
                This is probably an infinite loop.
                Further execution of actions has been disabled in this movie.
                • 5. Re: as2 predicted trajectory
                  use:
                  gun.onMouseDown = function() {
                      if (_ymouse<gun._y) {
                          trgt._x = 400;
                          trgt._y = 280;
                      } else if (_ymouse>gun._y) {
                          trgt._x = 380;
                          trgt._y = 350;
                      paramsF();
                      initTrajectoryF();
                  paramsF();
                  initTrajectoryF();
                      bulletSpeed = 6;
                      bullet._x = gun._x;
                      bullet._y = gun._y;
                      lineobj.clear();
                      if (_root.trgt.hitTest(bullet)) {
                          bullet.xStep = 0;
                          bullet.yStep = 0;
                          bullet.gravity = 0;
                      } else {
                  • 6. Re: as2 predicted trajectory
                    pa-pavel Level 1
                    Ignore this msg...got it sorted ty so so so much!!
                    Hey thx again so this is how my code is looking right now:
                    var Speed = 30;
                    var Gravity = 2.5;
                    gun.onPress = function()
                              gun.onEnterFrame = function()
                                        if (topbox.hitTest(_xmouse, _ymouse, true))
                                                  trace("topbox");
                                                  trgt._x = 380;
                                                  trgt._y = 350;
                                                  if (Speed >= 10)
                                                            //Speed-=.2
                                        else if (bottombox.hitTest(_xmouse, _ymouse, true))
                                                  trace("bottombox");
                                                  trgt._x = 400;
                                                  trgt._y = 280;
                              paramsF();
                              initTrajectoryF();
                    gun.onRelease = function()
                              delete gun.onEnterFrame;
                              lineobj.clear();
                              bulletSpeed = Speed;
                              bullet.gravity = Gravity;
                              xd = trgt._x - gun._x;
                              yd = trgt._y - gun._y;
                              dist = Math.sqrt(xd * xd + yd * yd);
                              flight = Math.ceil(dist / bulletSpeed);
                              bullet._x = gun._x;
                              bullet._y = gun._y;
                              bullet.xStep = xd / flight;
                              bullet.yStep = yd / flight;
                              bullet.yStep -= flight * bullet.gravity / 2;
                              with (this)
                                        _x += xStep;
                                        _y += yStep;
                                        yStep += gravity;
                                                  xStep = 0;
                                                  yStep = 0;
                                                  gravity = 0;
                                                  _visible = false;
                    //paramsF();
                    //initTrajectoryF();
                    paramsF();
                    initTrajectoryF();
                    function paramsF()
                              bullet._x = gun._x;
                              bullet._y = gun._y;
                              lineobj.clear();
                                        bullet.xStep = 0;
                                        bullet.yStep = 0;
                                        bullet.gravity = 0;
                              else
                    But the line still doesnt adjust itself according to the target.
                    Any ideas? Sorry to keep bothering you with this, really appriciate your help!
                    Thx Pavel
                    • 7. Re: as2 predicted trajectory
                      you're welcome.
