2 Replies Latest reply on Jan 15, 2013 8:58 AM by Scott Brodersen
    Nodetype Administration not accessible as described
    u005078
      The document "Nodetype Administration" does not describe this dialog can be invoked. In "Exploring CRX" I found that  "localhost:4502/crx/index.jsp" will call the CRX main console where the Nodetype Administration can be chosen. Unfortunately this does not work for my local cq5-quickstart.jar. Just to verify, I started a completely new instance to make sure that I had not modified something. But the problem didn't disappear.
      The messages I get when typing "http://localhost:4504/crx/index.jsp" to my browser (yes I have started my new instance with port 4504) are:
      No resource found
      Cannot serve request to /crx/index.jsp in /libs/sling/servlet/errorhandler/404.jsp
      Request Progress:
         0 (2013-01-15 16:31:33) TIMER_START{Request Processing}
            0 (2013-01-15 16:31:33) COMMENT timer_end format is {<elapsed msec>,<timer name>} <optional message>
            0 (2013-01-15 16:31:33) LOG Method=GET, PathInfo=/crx/index.jsp
            0 (2013-01-15 16:31:33) TIMER_START{ResourceResolution}
           31 (2013-01-15 16:31:33) TIMER_END{31,ResourceResolution} URI=/crx/index.jsp resolves to Resource=NonExistingResource, path=/crx/index.jsp
           31 (2013-01-15 16:31:33) LOG Resource Path Info: SlingRequestPathInfo: path='/crx/index.jsp', selectorString='null', extension='jsp', suffix='null'
           31 (2013-01-15 16:31:33) TIMER_START{ServletResolution}
           31 (2013-01-15 16:31:33) TIMER_START{resolveServlet(NonExistingResource, path=/crx/index.jsp)}
           31 (2013-01-15 16:31:33) LOG {0}: no servlet found
           31 (2013-01-15 16:31:33) TIMER_END{0,resolveServlet(NonExistingResource, path=/crx/index.jsp)} Using servlet org.apache.sling.servlets.get.DefaultGetServlet
           31 (2013-01-15 16:31:33) TIMER_END{0,ServletResolution} URI=/crx/index.jsp handled by Servlet=org.apache.sling.servlets.get.DefaultGetServlet
           31 (2013-01-15 16:31:33) LOG Applying Requestfilters
           31 (2013-01-15 16:31:33) LOG Calling filter: org.apache.sling.bgservlets.impl.BackgroundServletStarterFilter
           31 (2013-01-15 16:31:33) LOG Calling filter: org.apache.sling.rewriter.impl.RewriterFilter
           31 (2013-01-15 16:31:33) LOG Calling filter: com.day.cq.wcm.core.impl.WCMRequestFilter
           31 (2013-01-15 16:31:33) LOG Calling filter: org.apache.sling.i18n.impl.I18NFilter
           31 (2013-01-15 16:31:33) LOG Calling filter: com.day.cq.theme.impl.ThemeResolverFilter
           31 (2013-01-15 16:31:33) LOG Calling filter: com.day.cq.wcm.foundation.forms.impl.FormsHandlingServlet
           31 (2013-01-15 16:31:33) LOG Calling filter: org.apache.sling.engine.impl.debug.RequestProgressTrackerLogFilter
           31 (2013-01-15 16:31:33) LOG Calling filter: com.day.cq.wcm.mobile.core.impl.redirect.RedirectFilter
           31 (2013-01-15 16:31:33) LOG RedirectFilter did not redirect (request extension does not match)
           31 (2013-01-15 16:31:33) LOG Calling filter: com.day.cq.wcm.core.impl.warp.TimeWarpFilter
           31 (2013-01-15 16:31:33) LOG Applying Componentfilters
           31 (2013-01-15 16:31:33) LOG Calling filter: com.day.cq.wcm.core.impl.WCMComponentFilter
           31 (2013-01-15 16:31:33) LOG Calling filter: com.day.cq.wcm.core.impl.WCMDebugFilter
           31 (2013-01-15 16:31:33) TIMER_START{org.apache.sling.servlets.get.DefaultGetServlet#0}
           31 (2013-01-15 16:31:33) TIMER_END{0,org.apache.sling.servlets.get.DefaultGetServlet#0}
           31 (2013-01-15 16:31:33) LOG Applying Error filters
           31 (2013-01-15 16:31:33) TIMER_START{handleError:status=404}
          109 (2013-01-15 16:31:33) TIMER_END{78,handleError:status=404} Using handler /libs/sling/servlet/errorhandler/404.jsp
         1014 (2013-01-15 16:31:34) LOG Found processor for post processing ProcessorConfiguration: {contentTypes=[text/html],order=-1, active=true, valid=true, processErrorResponse=true, pipeline=(generator=Config(type=htmlparser, config={}), transformers=(Config(type=linkchecker, config={}), Config(type=mobile, config=org.apache.sling.jcr.resource.JcrPropertyMap@d2aade5), Config(type=mobiledebug, config=org.apache.sling.jcr.resource.JcrPropertyMap@6cfe9c23), Config(type=contentsync, config=org.apache.sling.jcr.resource.JcrPropertyMap@3fbcf5bc), serializer=Config(type=htmlwriter, config={}))}
         1014 (2013-01-15 16:31:34) TIMER_END{1014,Request Processing} Dumping SlingRequestProgressTracker Entries
      So this description seems not to work any more. Is there another URL / Link available?
      Ulrich
