5 Replies Latest reply on Jan 17, 2013 9:45 AM by murph2068
    New System Build Help
    murph2068
      Video Editing Build
      Premiere Pro & AE
      Drive layout
      C: SSD - OS and Programs
      SAMSUNG 840 Pro Series MZ-7PD256BW 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
      D: 1TB - Projects/Scratch
      Western Digital WD Black WD2002FAEX 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
      E: 3TB - Media (with offsite bachup)
      Seagate Barracuda 7200.14 ST3000DM001 3TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
      F: 250 GB - Exports
      Western Digital WD VelociRaptor WD2500HHTZ 250GB 10000 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
      G: SSD - Global Cache (for After Effects)
      SAMSUNG 840 Pro Series MZ-7PD128BW 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
      NZXT Phantom PHAN-001RD Red Steel / Plastic ATX Full Tower Computer Case
      ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
      EVGA 04G-P4-3687-KR GeForce GTX 680 FTW+ w/Backplate 4GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
      Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73930K
      COOLER MASTER GX Series RS750-ACAAD3-US 750W ATX12V v2.31 SLI Ready 80 PLUS BRONZE Certified Active PFC Power Supply
      2 CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMZ16GX3M2A1866C9
      Microsoft Windows 7 Professional SP1 64-bit - OEM
      CORSAIR Hydro Series H100i Water Cooler
      Koutech IO-RCM630 Multi-in-1 USB 3.0 SuperSpeed Front Panel Internal Card Reader with USB 3.0 Port (3.5")
      ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
      Total $2912.83
      Would have liked a raid 5 for media but the Asus X79 does not have enough Sata 6Gb/s the Asrock version has but does not have the SSD Caching port
      which I think and hope will work well with the 2 SSD cards. 1 for the OS and the other for the Globel cache for AE (not set up as raid 0)
      Maybe down the road I could add a seperate raid card to run 3 extra drives on a raid 5 ?
      Any way I would love to your feed back from you guys before I pull the lever on this as all this jazz is pretty new to me. I have built a few systems in the past but
      would like to get better on AE. Going this time for ease of performance and as little bottlenecks as I can and at the same time keeping it simple.
      Cheers
      Murph I am no expert as this
      Found this on  Adobe TV  How to optimize AE for High Performance. It made the most sence to me.
      http://www.youtube.com/watch?v=a4D9ScFcM3M
        • 1. Re: New System Build Help
          RjL190365 Level 4
          Looks good except for the PSU. That Cooler Master GX series PSU is not a true 750W PSU to begin with. In fact, it cannot reliably handle more than about 500W without killing off some of your PC's vital components. So, that PSU is totally unsuitable for a PC with such a higher-end, power-hungry CPU and GPU and more than a single disk.
          • 2. Re: New System Build Help
            murph2068 Level 1
            Thanks will look into that. What power supply would you reccomend ?
            • 3. Re: New System Build Help
              RjL190365 Level 4
              With the disks that you have listed, go with a Corsair AX760i (which can handle its full 760W rating and then some, unlike the GX750). If you plan to add a few more disks in the near future, then go with the AX860i. However, you will have to pay quite a bit more money for such higher quality.
              Note that I don't work for Corsair, but it is one of the few brands that do not have any really bad PSUs in the lineup.
              • 4. Re: New System Build Help
                murph2068 Level 1
                Yep the AX860i is quite a bit more but yes having the a quality power supply available for extra disks sounds like a good idea.Still close to a $3000 system
                • 5. Re: New System Build Help
                  murph2068 Level 1
                  Update just wondering which disc setup would work best with my set up for the best performance ?
                               ASUS Sabertooth X79
                               Option 1
                               C:  OS and Program SAMSUNG 840 Pro                                                  (6Gb/s SSD caching sata)
                               D:  Projects/Scratch WD Black  2TB 7200                                                (6Gb/s sata)
                               E:   Media. Seagate Barracuda 7200 3TB                                                   (6Gb/s sata)
                               F:   Exports. WD VelociRaptor 250GB 10000 RPM                              (3Gb/s sata)
                               G: SSD - Globel Cache (for After effects) SAMSUNG 840 Pro 120GB         (6Gb/s SSD caching sata)
                               Option 2 ( pretty much the same as mellofell13, members setup)
                               C:  OS and Program SAMSUNG 840 Pro 256GB                                       (6Gb/s SSD caching sata)
                               D:  Media & Projects 2x Western Digital 1TB Caviar black Raid 0                (6Gb/s sata) Marvell
                               E:  Exports & previews. 2x Western Digital 1TB Caviar black Raid 0            (3Gb/s sata)
                               F:  temp files, media cache, Globel Cache (for After effects)
                              Just trying to make the final dicision on this any help would be greatly appreciated
                              Thankyou
