4 Replies Latest reply on Jan 21, 2013 1:27 PM by bbiggs40
    Numbering Instances of a Subform
    bbiggs40 Level 1
                I have a maintenance form where each item that gets inspected needs to have a unique number. The Item # is a Numeric Field and I have tried many different ways to count the Subform1 instances but nothing works 100% of the time.  The issue is I can count the instances on initialize or I can add 1 to the index but it doesn't work if I need to remove sections. I need to find a way that correctly identifies the item number despite errors made by the user when they need to remove sections. I've also tried just have the item # be the page number but some inspections last more than one page so this is not a solution either.
      Thanks for you help - I'm sure the answer is fairly simple (the form is built in javascript)
