1 Reply Latest reply on Jan 21, 2008 11:26 AM by mmh67
    axis problem
    mmh67
      I created a simple model with three members. It is basically a room with two objects in it. I want to be able to rotate from a front view to a top view and rearrange the objects. The problem is that every time I rotate the camera to a top view, the axis of the two objects seems to move as well. This means if I try to rotate the objects along the x-axis in the front view everything is fine, but once I rotate to a top view, the object is now rotating along a different axis. I have used both custom scripts and library scripts to rotate the camera with the same result. I am using the library objects to drag and rotate the objects in the model.
      If anyone can shed some light on what I am doing wrong, I would appreciate it.
      Michael
