3 Replies Latest reply on Jan 16, 2013 5:36 AM by Peter Kahrel
    check box EXPORT Options
    hurix@123 Level 1
      I have a script for EXPORT Options.
      displayDialog();
        function displayDialog(){
                var arrSizes = ['XML'];
          var arrSizes1 = ['WEBPDF'];
          var arrSizes2 = ['PS'];
          var arrSizes3 = ['EPUB'];
                var win = new Window('dialog');
          var stxPrompt = win.add('statictext', [0, 0, 200, 20], 'EXPORT OPTIONS');
                var Checkbox = win.add('checkbox', [50, 30, 250, 50], arrSizes);
                    var Checkbox = win.add('checkbox', [50, 30, 250, 50], arrSizes1);
                        var Checkbox = win.add('checkbox', [50, 30, 250, 50], arrSizes2);
                            var Checkbox = win.add('checkbox', [50, 30, 250, 50], arrSizes3);
                var btnOK = win.add('button', [0, 60, 100, 80], 'OK');
                win.show();
                var strChoice = Checkbox.selection;
      if(strChoice !=null){
      switch(strChoice){
      case "XML":
                      app.doScript(new File("/Volumes/HPP/1_Delivery/Prepress/5_Production/Book/Sage_Books/P16230510_Sage Books_XML/Templates/PHOTINO/FULL BOOK/SCRIPT/Post Process.jsx"), ScriptLanguage.JAVASCRIPT);
                          break;
                          case "PS":
                      app.doScript(new File("/Volumes/HPP/1_Delivery/Prepress/5_Production/Book/Sage_Books/P16230510_Sage Books_XML/Templates/PALATINO/FULL BOOK/SCRIPT/Post Process.jsx"), ScriptLanguage.JAVASCRIPT);
                          break;
      when i click XML and PS options and then OK there is no action is running.
      Please suggest me.
      Hurix
        • 1. Re: check box EXPORT Options
          Jump_Over Level 5
          At first look:
          You have to insert "case" code into "{}":
          case"XML":{your code; your code; break;}
          rgds
          • 2. Re: check box EXPORT Options
            Vamitul Level 4
            jump. nope. the syntax for case does not require {};
            hurix..the problem is tha your dialog is a.. 'dialog', so it's modal. while it is active, you cannot interact with indesign.
            a quick fix: var win = new Window('palette');
            should work
            • 3. Re: check box EXPORT Options
              Peter Kahrel Adobe Community Professional & MVP
              Some problems with your code:
              - checkboxes have a value property, they don't have a selection property;
              - you add four checkboxes, but you assign them to the same variable, so the script sees just the last defined instance;
              - why do you define the text labels for the checkboxes as arrays? This is not necessary.
              - you probably want radiobuttons, not checkboxes -- is that so?
              - the check whether strChoice is null is not needed because Checkbox (be it a checkbox or a radiobutton) always has a value;
              Peter
