1 Reply Latest reply on Aug 10, 2007 2:05 PM by ntsiii
    Storing data without a server
    zorglub76
      Hi all
      I need your opinion on the problem I have and solution for it.
      Problem:
      I need to create some kind of reporting engine with as few files as possible and with no server to work in background.
      Solution:
      Some swf/sqlite bundle.
      Q1: Is this solution possible?
      I'm a newbie and, as far as i know, you either need a sqlite connector to communicate with db, or use of fscommand(). Since there are no open source connectors, I'm interested in fscommand, so
      Q2: Can I use sqlite (or any such portable db) with fscommand (basically, can I fetch response from it)?
      I'm also not sure that I need a db at all. The data structure is pretty simple, so a single xml would do, which brings me to
      Q3: Can I write to an xml file from a swf?
      Thanks in advance!
        • 1. Re: Storing data without a server
          ntsiii Level 3
          You should use Adobe AIR for this. mySQL is built in.
          Flex in the FlashPlayer in a browser will require server-side functionality. Unless you physically install it on a client in a trusted sandbox, it cannot access the local file system. AIR can, and more,
          Tracy
