5 Replies Latest reply on Jan 17, 2013 7:15 AM by kglad
    aim line - looping animation plz help!
    pa-pavel Level 1
      Hi.
      Hope someone can help me a bit stuck.
      import com.greensock.*;
      import com.greensock.easing.*;
      var TN = TweenNano;
      var newobjtimer;
      TN.to(p2,15,{_x:500});//
      newobjtimer = setInterval(createnewball, 600);
      function createnewball():Void
                          this.attachMovie("Ball","ball1",{_x:p2._x, _y:p2._y});
                          trace(ball1._x)
      The create ball keeps disapearing and I need to add a new ball each time the timer triggers and for all of them to be in their own place.
      Any help is appriciated.
      thx pavel
        • 1. Re: aim line - looping animation plz help!
          that's going to be a problem unless you stop adding movieclips at some point.
          but your error is you have failed to assign a depth for Ball.  the third parameter in attachMovie should be an available depth.
          • 2. Re: aim line - looping animation plz help!
            pa-pavel Level 1
            Hey,
            I got this now
            i++
            attachMovie("Ball","ball" + i,i,{_x:bullet._x, _y:bullet._y, _height:["ball" + i]._height-(i*.3), _width:["ball" + i]._width-(i*.3)});
            but the size of the 'ball' doesnt change how i want it...I want them to get small and smaller.
            And struggleing to rremove them all.
            cheers
            • 3. Re: aim line - looping animation plz help!
              i++
              var ball:MovieClip = attachMovie("Ball","ball" + i,i,{_x:bullet._x, _y:bullet._y,});   // i'm not sure your positioning is what you want, either.
              ball._xscale=ball._yscale = 100-i*3;
              • 4. Re: aim line - looping animation plz help!
                pa-pavel Level 1
                Thx for the reply
                here is the full code:
                I am struggling to remove all the dots onMouseUp, always one dot gets left behind.
                var TN = TweenNano;
                var newobjtimer;
                var i = 0;
                var Speed
                var Gravity
                bullet._visible = true;
                gun.box._visible = false;
                gun.onMouseDown = function()
                          tracker._visible = true;
                          gun.onEnterFrame = function()
                                    if (topbox.hitTest(_xmouse, _ymouse, true))
                                              //trace("topbox");
                                              trgt._x = 450;
                                              trgt._y = 280;
                                              Speed = 15;
                                              Gravity = .5;
                                    else if (bottombox.hitTest(_xmouse, _ymouse, true))
                                              //trace("bottombox");
                                              trgt._x = 397;
                                              trgt._y = 350;
                                              Speed = 15;
                                              Gravity = 3.3;
                                    paramsF();
                                    initTrajectoryF();
                gun.onMouseUp = function()
                          trace(i)
                          for (var q = 0; q < i; q++)
                                     removeMovieClip(_root["ball" + q]);
                          i = 0;
                          delete updateTrajectoryF ();
                          tracker._visible = false;
                          delete gun.onEnterFrame;
                          lineobj.clear();
                          bulletSpeed = Speed;
                          bullet.gravity = Gravity;
                          xd = trgt._x - gun._x;
                          yd = trgt._y - gun._y;
                          dist = Math.sqrt(xd * xd + yd * yd);
                          flight = Math.ceil(dist / bulletSpeed);
                          bullet._x = gun._x;
                          bullet._y = gun._y;
                          bullet.xStep = xd / flight;
                          bullet.yStep = yd / flight;
                          bullet.yStep -= flight * bullet.gravity / 2;
                bullet.onEnterFrame = function()
                          with (this)
                                    _x += xStep;
                                    _y += yStep;
                                    yStep += gravity;
                                    if (_root.trgt.hitTest(_x, _y, true))
                                              xStep = 0;
                                              yStep = 0;
                                              gravity = 0;
                                              //_visible = false;
                this.createEmptyMovieClip("lineobj",getNextHighestDepth());
                var trajectoryI:Number;
                //paramsF();
                //initTrajectoryF();
                function paramsF()
                          bullet._x = gun._x;
                          bullet._y = gun._y;
                function initTrajectoryF():Void
                          lineobj.clear();
                          lineobj.lineStyle(1,0xCD1B83,100);
                          lineobj.moveTo(gun._x,gun._y);
                          lineobj._visible = false;
                          updateTrajectoryF();
                function updateTrajectoryF():Void
                          lineobj.lineTo(bullet._x,bullet._y);
                          bullet._x += bullet.xStep;
                          bullet._y += bullet.yStep;
                          if (i < 15)
                                    i++;
                                    attachMovie("Ball","ball" + i,i,{_x:bullet._x, _y:bullet._y, _yscale :100-i*3, _xscale:100-i*3});
                          //trace("ball height " + ["ball" + i]._height);
                          bullet.yStep += bullet.gravity;
                          if (_root.trgt.hitTest(bullet))
                                    //i = 0;
                                    //trace(i)
                                    bullet.xStep = 0;
                                    bullet.yStep = 0;
                                    bullet.gravity = 0;
                                    bullet._visible = false;
                          else
                • 5. Re: aim line - looping animation plz help!
                  use:
                    for (var q = 1; q <= i; q++)
