13 Replies Latest reply on Aug 11, 2007 12:33 AM by batmitra
    using flex with .net
    Michael_Lahzy
      could i connect to flex sdk from c3 and use all the functionality?
        • 1. Re: using flex with .net
          batmitra Level 1
          hi
          yes you can connect from c# to flex, but it depends on what you want to do, i'm using vb.net and flex, and i connect using httpservice or webservices .
          • 2. Re: using flex with .net
            Michael_Lahzy Level 1
            to register the webservice... what i need to download... i downloaded the flex builder but that didn't help me
            so how could i register the webservice
            thx
            • 3. Re: using flex with .net
              ntsiii Level 3
              Describe your goals in a bit more detail. I can't even begin with "connect" and "all the functionality".
              Tracy
              • 4. Re: using flex with .net
                hi,
                i have a website with data stored in the database... i want to report on this data
                i know flex has cool reporting functinalities in the samples on the site
                so i want to pull the data from db and send it to flex with whatever configuration I need as the chart type and any required data which i expect to display the data in the report i want
                plz let me know if u need more clarification
                thx a lot
                • 5. Re: using flex with .net
                  ntsiii Level 3
                  That's clear.
                  First, are you sure you need SOAP? Do you plan to make your data publicly availiable and need anonymous third parties to be able to build clients to consume your data using the wsdl?
                  SOAP based Webservice is complex, the namespace issues make it difficult to use in Flex, and because of the additional xml, it is slightly slower.
                  If you just need to get your data into Flex, use HTTPService. It is simpler to build and to consume. HTTPService is like the "XMLHTTP" class in .net. Use an aspx page with Response.ContentType = "text/xml", and no visual UI.
                  I have a couple examples on cflex.net. Search for asp.net.
                  Tracy
                  • 6. Re: using flex with .net
                    batmitra Level 1
                    Hi
                    Tracy, i'm using webservices, because of security issues, but perhaps i'm wrong, my webservices are not for public use so i can use httpservice, doesn't that compromise security in cases where we have to pass sensitive information thru http?
                    • 7. Re: using flex with .net
                      ntsiii Level 3
                      Webservices aren't any more secure inherently than HTTPService . Webservice is just protocol, an xml format, designed for data transport. You can secure web services and you can secure HTTPService. You can require authentication on both and you can encrypt sensitive data on both.
                      Tracy
                      • 8. Re: using flex with .net
                        batmitra Level 1
                        Hi
                        Can you give examples of how can i secure httpservice? And how can i encrypt my sensitive data using httpservice and .net?
                        Just one more question, i have a menubar wich i'd like to populate with icons, how can i do it dynamically, without having to embed my images on an mxml file?
                        • 9. Re: using flex with .net
                          batmitra Level 1
                          hi
                          tracy i remember something else, that's what made me opt for webservices, on HttpServices i don't know how to have several operations, unless i send a parameter to aspx page saying wich operation i want.
                          With webservices i can have multiple operations since every method i write is in fact an operation.
                          Can you clear me on this? is there a way to have HttpServices requesting several operations?
                          • 10. Re: using flex with .net
                            Tracy & batmitra
                            Thanks for your contribution... it cleared a lot of stuff for me... but I am still missing something
                            when I use httprequest or webservice I should post on a traget URL... I don't know how to get this URL... so what I need to install/download to get that URL installed on my development machine, and use flex functionalities
                            Thanks a lot,
                            Michael
                            • 11. Re: using flex with .net
                              batmitra Level 1
                              hi
                              Michael , sorry but you lost me , i didn't understand your question, could you be more specific about it? What do you want to do exactly?
                              • 12. Re: using flex with .net
                                ntsiii Level 3
                                batmitra, you are right, HTTPService does not have the concept of "operation" . that is provided by the SOAP protocol. But whay do you care? Just do as you say and pass an 'action=" request parameter that tells the aspx page what code to run and return.
                                Tracy
                                • 13. Re: using flex with .net
                                  batmitra Level 1
                                  hi
                                  thanks for replying, i will be considering the use of httpservices, since it's a lot easier to send data back and forward to flex.
