3 Replies Latest reply on Feb 7, 2008 6:33 AM by Hagster
    vertical text  ish, prob with charting
    Hagster Level 1
      Hello All,
      Firstly you might tell me to bugger off since im using Bluedragon and not CF (CF 7 would get rid of my problem) so any how im trying to create a work around.
      OK here goes:
      I have a CFCHART (all works great)
      The parameter in ;
      CFCHARTDATA item='data label here'
      always renders as horizontal on the data labels, in CF 7 you can use a style sheet to customise this attribute to render vertically I believe the value is something like;
      labelstyle isHideOverlapped TRUE orientation=Horizontal
      Ok but I dont have this luxory in Bluedragon, but I have noticed I can get vertical text if I preset a variable like below.
      CFSET dataname = 'JOE'
      (if I use this as my item parameter
      CFCHARTDATA item= dataname
      I get horizontal text as you would exspect.
      CFSET dataname = '
      J
      O
      E
      If I use the dataname variable set like above I get nice Vertical Text.
      So I thought Im on a roll here, I have been trying to work out some loop to just format my datanames like above but I cant work it out. any ideas.
      Or my other metod would be to somehow set the dataname variable against a CSS stlye.
      I can set a stlye up in the header and then Is it possible to apply that class stlye against a variable?
      these are the two work arounds im trying but Im not having much success.
      Any one got any ideas pleaase
      Kind Regards Guy
      Sorry messed up attaching code etc, been a long day so far.
