5 Replies Latest reply on Aug 10, 2007 12:41 PM by >Vee<
    Loading swf's not working
    FlashForumName Level 1
      Hello all. I have a 'UI' module that loads in other swf files based upon which button the user clicks. It is able to locate and load the swf files with no problems. The problem arises with combo boxes. Whenever the swf loaded with the loader has a combo box, the box does not work properly. When you select an item, sometimes you get that item, the one above it, one 2 after it, etc. I have no idea why this is happening and would greatly appreciate some help. I'll attach my small segment of loading code, maybe the problem is there but I don't see it.
      The function launcher is called by the buttons with a string to the location of the swf. The loader is able to find these swf's but the combo boxes just do not work properly.
