1 Reply Latest reply on Jan 17, 2013 12:32 PM by try67
    Dropdown List
    01371406 Level 1
      I have a dropdown box with a list of choices. I would like the box to be larger upon viewing the list, then smaller after selection. For instance.
      One of the choices on the list is:
      Pilodunk, Rachel S.                                                 Securities and Exchange Senior Level Manager
      But I only want to see the name Pilodunk, Rachel S. after the user exits the selection. Not their title. Is this possible with javascript? I have tried the code:
      var DV=new Array("","Pilodunk, Rachel S.                                               Securities and Exchange Senior Level Manager", "Next, Name Title")
      var DF = this.getField("NameTitle");
      DF.setItems(DV);
      But it doesn't show the title because the box isn't that wide. It will show the name.
        • 1. Re: Dropdown List
          No, it's not possible, but there are other ways of doing it. For example,
          you can use a button and a text field.
          The button will launch a script that will display the full name and title
          using a pop-up menu, and will then populate the text field with just the
          name when the user makes a selection.
