0 Replies Latest reply on Jan 17, 2013 11:48 AM by bwong82
    Problem deleting resources when doing a clean from an ANT build script
    bwong82
      Hello.
      I'm trying to incorporate an ant build script to be used in the FlashBuilder IDE, but I am running into an issue when trying to delete a swc file that is created when running the 'clean' target.
      I get the error that "Problem Occurred"
      'Deleting files...' has encountered a problem.  Problems encourntered while deleting resources.
      Problems encountered while deleting resources.
      Could not delete 'C:\project_src\trunk\flash\labs\bin\commonUtilities.swc'.
      Problems encountered while deleting files.
      Could not delete: C:\project_src\trunk\flash\labs\bin\commonUtilities.swc.
      This error occurs even when I try to delete by right clicking from the Package Explorer in Flash Builder.  When I try to delete it from Windows Explorer I get an error stating that FlashBuilder.exe is using the file.  This makes me suspect that somehow Flash Builder has locked this file.  In order for the clean to work I need to close FlashBuilder and then reopen it.
      One interesting note, is that once I reopen Flash Builder and if I do a clean/build repeatly just ONLY the swc project it works without fail, BUT once I try to do a full build with the main project, linking does the 'lock' happen.
      This problem does not occur if I am using the default "Flex" in the Builders under the Properties for the project.  It only occurs when I import and use my own build file.
      I'm extremely new to ant and using the flex compiler.  I'm using the <compc> to compile my swc file.  Does the <compc> some how cause FlashBuilder to hold on to the swc file produced?
      Buildfile: C:\project_src\trunk\flash\master-build.xml
      clean-labs:
            [delete] Deleting C:\project_src\trunk\flash\labs\bin\commonUtilities.swc
      BUILD FAILED
      C:\project_src\trunk\flash\master-build.xml:37: Unable to delete file C:\project_src\trunk\flash\labs\bin\commonUtilities.swc
      Total time: 614 milliseconds
      I'm using the following:
          [echo] ANT_HOME: C:/apache-ant-1.8.4
          [echo] flexTasks jar location: C:/apache-ant-1.8.4/lib/flexTasks.jar
          [echo] FLEX_HOME: C:/Program Files (x86)/Adobe/Adobe Flash Builder 4.5/sdks/4.5.0
          [echo] BRANCH_BASE: C:/justice_src/trunk/
          [echo] DEBUG: false
      Here's the target for clean-labs:
      <target name="clean-labs">
            <delete verbose="true" failOnError="true">
                    <fileset dir="${BRANCH_BASE}/flash/labs/bin/" includes="labs.swc" />
             </delete>
      </target>
      The build target for the swc for the compc part is as follows:
      <compc output="${BRANCH_BASE}/flash/labs/bin/commonUtilities.swc"
                                       debug="${DEBUG}"
                                       locale="en_US"
                                       incremental="true" >
      The build target for the main project is using <mxmlc> and includes
      <compiler.library-path dir="${BRANCH_BASE}/flash/labs/bin/" append="true">
          <include name="commonUtilities.swc" />
      </compiler.library-path>
      Does anyone have any idea what is going on? Any thoughts on solutions and workarounds are greatly appreciated.
