5 Replies Latest reply on Jan 18, 2013 2:24 PM by Flex harUI
    Flex bug in global error handling
    RichBelaK
      My application's global error handler (uncaught error handler) works mostly, but I found a case where it doesn't work, but should.  Before I filed an official bug report I wanted to post the issue here.
      Here is the issue: in a module, ErrorEvents that are not listened for  and are dispatched by a Flex component are never caught in the application's uncaught error handler.
      I have a sample project that demonstrates this.  Here is the module in my test case:
      <s:Module xmlns:fx="http://ns.adobe.com/mxml/2009"
                   xmlns:mx="library://ns.adobe.com/flex/mx">
      <fx:Script>
          <![CDATA[
              private function onClickSparkDispatch():void {
                  dispatchEvent( new ErrorEvent( ErrorEvent.ERROR, false, false, "test" ) );   // this isn't caught in the uncaught error handler
              private function onClickNonSparkDispatch():void {
                  var nonSparkDispatcher:EventDispatcher = new EventDispatcher();
                  nonSparkDispatcher.dispatchEvent( new ErrorEvent( ErrorEvent.ERROR, false, false, "test" ) );  // this is caught in the uncaught error handler
      </fx:Script>
          <s:HGroup>
              <s:Button label="Module Spark Dispatch (broken)" click="onClickSparkDispatch()" />
              <s:Button label="Module Non-Spark Dispatch" click="onClickNonSparkDispatch()" />
          </s:HGroup>
      </s:Module>
      Using Flex 4.6
      My application statically links in the Flex SDK ("merged into code" in Flash Builder).
      My applications works around these two exsiting bugs:
           https://bugs.adobe.com/jira/browse/SDK-28018
           http://blogs.adobe.com/aharui/2011/04/catching-uncaughterror-in-flex-modules.html
      Is this a bug?
      Rick
