1. Re: 1080 50p live with sound - have no sound in PP 5.5
Greg Baber Jan 17, 2013 3:24 PM (in response to anat_usa)Typically with this issue there is a problem with the audio codec that you are importing. This is a document that gives troubleshooting steps.
2. Re: 1080 50p live with sound - have no sound in PP 5.5
John T Smith Jan 17, 2013 3:42 PM (in response to anat_usa)What are you editing, and does your project match your video?
For CS5 and later, the easy way to insure that your video and your project match
See 2nd post for picture of NEW ITEM process http://forums.adobe.com/thread/872666
-and a FAQ on sequence setting http://forums.adobe.com/message/3804341
Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
What is a CODEC... a Primer http://forums.adobe.com/thread/546811
What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
http://forums.adobe.com/thread/592070?tstart=30
For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
3. Re: 1080 50p live with sound - have no sound in PP 5.5
anat_usa Jan 17, 2013 4:27 PM (in response to John T Smith)well i dont edit anything yet- i get no sound and dont know what to do.
its avchd h.264 sound is lpcm. 1080 50p
yes project does match the video, also its the only clip i have on time line there are no any other clips in different formats or anything like that....
i am on Win 7 64bit , i have quicktime pro and divx pro installed
i tried with same codec but 1080 25p and its good - when i add clip on time line i get 2 separate roads : 1 for video and 1 for sound, but if i put 1080 50p on time line i get no sound.....
4. Re: 1080 50p live with sound - have no sound in PP 5.5
JSS1138 Jan 17, 2013 4:47 PM (in response to anat_usa)This is not the first issue I've seen with 1080p/50. Might be best to just not use it. You can't put it on disk or deliver for broadcast.
5. Re: 1080 50p live with sound - have no sound in PP 5.5
Bill Hunt Jan 17, 2013 5:48 PM (in response to anat_usa)Thank you for the above info.
Two questions:
- When you Copied your AVCHD material to your computer, did you Copy the full folder structure?
- When you Imported the media files, did you allow Conforming to complete 100%? See this article: http://forums.adobe.com/message/3892177#3892177
6. Re: 1080 50p live with sound - have no sound in PP 5.5
anat_usa Jan 22, 2013 9:27 AM (in response to Bill Hunt)hello
yes i copied full folder structure from my SD card to my pc. what would be the very RIGHT way to put files in PP....... i am new to PP and would be greatfull for step by step procedure..
7. Re: 1080 50p live with sound - have no sound in PP 5.5
Greg Baber Jan 22, 2013 9:39 AM (in response to anat_usa)First step, copy the full folder structure from your SD card to your PC.
Second, using the Media Browser panel in Premiere Pro, go to the folder that contains the SD cards contents. The system should recognize the file structure and show the appropiate video clips.
Third, after choosing to import your footage, wait for the conforming to reach 100%.
