7 Replies Latest reply on Jan 21, 2013 8:20 AM by Jeff A Wright
    Liscense key is damaged.
    eldo77
      What does this mean?
        • 1. Re: Liscense key is damaged.
          attach a screenshot of the error message.
          • 2. Re: Liscense key is damaged.
            John Waller Adobe Community Professional & MVP
            It means what it says, I guess.
            Which Adobe product? Which operating system?
            • 3. Re: Liscense key is damaged.
              eldo77 Level 1
              Adobe Digital Editions.Windows XP..I don't even know what a liscense key is, but
              thats what the message box says when I try to open a previously downloaded
              e-book that I was actually able to read yesterday.
              I tried to download 3 e-books today from my regional library but couldn't read
              them either.Got a messa
              ge box that says: Unable to download..error getting liscense..Liscense Server
              Communication Problem...E_AUTH_
              BAD_DEVICE_KEY_OR_PKCS12
              • 4. Re: Liscense key is damaged.
                the is from bwolfe:
                regarding the E_AUTH_BAD_DEVICE_KEY error...
                We can't tell you -exactly- what this is, but we can give you some general direction.
                On the Mac, Digital Editions 1.5 stores an encryption key (to make sure our client to server calls are secure) in your OS X Keychain.
                If there is a problem creating this key then E_AUTH_BAD_DEVICE_KEY is the error you'd see.
                The key information is stored as an application password in your keychain. Likely causes of failure include denying access to Digital Editions, or locking your user keychain, and not entering their password when prompted.
                If you're denying access explicitly to Digital Editions, well don't do that (ha. )
                Now, you may not be doing this intentionally. The access permissions on OS X are complicated, so this could be a side effect of some other permission work. You can explicitly grant Digital Editions access to the the keychain item:
                Open Keychain Access (Applications/Utilities)
                Select Passwords from Category
                Select Digital Editions from password list
                Click info button (or press Cmd+i)
                (Dialog labeled Digital Editions should appear)
                Select Access Control tab
                Click + button
                Navigate to our install directory and select ADE 1x5
                Click Save
                Close Dialog
                Launch Digital Editions.
                Anyway, hopefully this helps you narrow the issue down.
                Regards,
                Bentley Wolfe
                Senior Support Engineer, Flash/Flash Player/Digital Editions
                Adobe
                • 5. Re: Liscense key is damaged.
                  eldo77 Level 1
                  I am using Windows XP.
                  • 6. Re: Liscense key is damaged.
                    • 7. Re: Liscense key is damaged.
                      Jeff A Wright Adobe Employee
                      Moving this discussion to the Adobe Digital Editions forum.
                      Please try downloading a book from our sample library at http://www.adobe.com/products/digital-editions/eBook.html.  If you are able to download the book successfully then please contact the support team responsible for your e-book downloads from your library.
